konadog wrote:Awesome - thanks for the detailed pictures. It looks like the hub change is pretty simple, no
? Just unbolt, slide out the old and slide in and bolt up the new... is it more complex than that? Thanks.
Scott, who suffers with a mild case of wrench phobia
Manual hubs are easy.
1. unscrew
auto (shiny) hub cap
2. Take out C-clip retainer (careful as it will pop out. You don't want to loose it)
3. Remove flat o-ring washer
4. Undo 8mm Allan bolts
5. Clean
6. Remove two allen bolts in the new Superwinch 'SW' hub (they come like that so they don't fall apart in the box)
7. Separate the two halves of the SW hub assembly (as in my pics)
8. Repeat in reverse steps 2-6
9. Put 2nd half (shiny cover) SW hub on with small (included) torx bolts. ** note. They are tiny and fragile. They do NOT need to be cranked on.
10. Enjoy being able to go up/down steep hills on 4Xlow with on the rear wheels engaged enabling you to turn the front wheels at full lock without binding anything (which happens in 4xlow/high with the transfercase engaged).
snelson wrote:terrific post - quick question. Simlilar to Kona's question but regarding the rotors, simple to get off on? Just a few bolts etc...?
Steve
Rotors are harder.
1. Steps 1-4 above
2. unscrew 4 phillips bolts that hold the retaining ring inside (see pic below) and removed
3. unscrew 2nd retaining clip (I used two screw drivers)
4. Remove caliper and caliper mounting brackets (17mm)
5. Slide hub/rotor off shaft (watch out for the bearings/seal)
6. on table remove 14mm bolts/nuts
7. press out the hub assembly from the rotor
8. reverse 1-5
The
auto -> manual hubs are the easiest part. The hub assembly / rotor separation , new rotor / hub assembly press in / bolt in, press in new bearings/races/seals is the hardest part.
Tools needed .
8mm allan socket - allan bolts holding
auto hub to hub assembly
10mm wrench -
brake line
12/14 mm wrench and deep socket - caliper bolts / hub assembly bolts/nuts
17mm socket - caliper mounting bracket
small torx (forgot size) - SW hubs
philips driver - retaining ring on shaft
C-clip pliers - remove c-clips
cutoff wheel - cut shield to fit larger brackets
Vice or table/something to prop the rotor/hub assembly to remove it.
If you do it at a shop on a hoist with the proper tools, you're looking at 2hr per side.
Without a shop/hoist/proper tools (air tools), I'd look at a full day unless you know what you're doing. 1st side is always the longest.
Jesse
