Conversion Kit FOR SALE
Posted: Fri Apr 17, 2015 3:26 pm
Change your diesel to run on FREE FUEL!!
All the stuff you need to covert your diesel to a 2 tank WVO/SVO system. Willing to separate some parts. I've been running this set up in my F350 for 3 years now and over 100,000km. It works great, I just sold the truck to downsize and don't need it any more. There is lots of free fuel out there!
http://whistler.craigslist.ca/pts/4965201351.html Please contact via Craiglist
I paid over $3500 for this kit. It's yours for around $400 OBO complete (depending on what you want)
Conversion Parts:
VM2 Filter (2 - 1 for WVO and 1 for diesel)
Vegtherm
3-port valves (you only need 2, but I'll include 4)
Inline heat exchanger
COOLANT-HEATED FILTERS: VM2 coolant heated filter with TWO filter element and fittings for fuel and coolant lines. The VM2 filter is heated by engine coolant, heat rises easily to the etop-mounted filter element. Drain valve provided to drain the integrated water separator and for use at filter change time. This filter drains and re-primes after a filter change very easy.
FITTINGS and HOSES: cooling system and fuel system connection fittings are provided with fuel and coolant line. You may want to install new lines as these are used, but that depends on your application. Hose-ON-Hose method means no risk of coolant loss into fuel from a cracked internal line.
HP-26 HOTPLATE COOLANT/SVO HEAT EXCHANGER
26 plate version suitable for big pickups and other buses, tractors, generators, and larger, higher fuel flow rate applications. Internally threaded 3/8" hose barb elbows and mounting bracket included.
Links for more information:
http://www.plantdrive.ca/index.php?main ... cts_id=104 (this link is only here for information, using this company is strongly NOT advised)
I also have all the stuff you need to filter WVO, including dewater and filter to 1 mircon. I've spent over $1000 on this stuff. I can include it in the deal for added cost or sell separately.
I have 200 liters of settled oil I can throw in with the deal too.
Conversion Parts:
Vegtherm
