L300 braided steel brake hose replacement ?
Lapprentis
Post by Lapprentis »
Can someone knows if there are braided steel brake hose available as a replacement for ours Delica ?
If not, does anyone knows how many stock rubber hose we do have and their lengh ?
Much Thanks
Lapprentis :M
nxski
Re: L300 braided steel brake hose replacement ?
Post by nxski »
I've seen these put on by Felix, but they need to be exactly the right length.
Lapprentis
Thanks, yes, that is why I am asking. Will keep in touch as this file evolve :-)
Lapprentis :M
Lapprentis
The info founded so far:
1-For front brake lines only:
From RHD Japan : APP Stainless Mesh Telfon Brake Lines MB-117SS (http://www.rhdjapan.com/app-stainless-m ... oyota.html). Also available in steel (MB-117ST).
2-For front and rear (info taken from Dino Evolution): dinoevo.de
1-From Russell (http://www.russellperformance.com/)
Front and rear (4x Russell 656012 (9″) 1x Russell 656062 (24″, shorter is fine if you don’t have a lift), 2x Russell 683942 (90 degree bracket) 2x 3/16 in. o.d. SAE inverted flare metric brake line with 2 pcs. M10 – 1.0 long tube nut fitting, Brake Fittings: 8x Russell 641411, 2x Russell 641431.
3-Go to your nearest (or online) custom made brake lines shop (http://edbrakeclutch.ca/service/brake-hoses/), etc. Take your hoses-lines to be replace in order to match the lenght: Measurements to be add to this thread by someone :shock:
I think there is enough info here for those who want to go throu this modification to start with: Add your own to enrich this thread :o
Lapprentis :M
macro
Vehicle: L400 "The Invader"
Post by macro »
Any hydraulic hose shop can make them up for you. All they need is length and end connection size!
