I just finished a headlight conversion to eCode pods. It made me wonder, these new pods had a 'city light' bulb receptacle in the high beam side. I'm not going to use it, but I wonder if that is what some suppliers are billing as the "running light" capable pod. If so, that is not very accurate as I certainly would not want a 5W bulb on the high beam side as my running light, and you'd still be better off using a DRL module than wiring something like that to your ignition I would think.
Also note that the European eCode lights have a four pin connector, whereas the Deli is 3. So what you need to do is strip out the original wiring harness (which is real thin 16 guage wire BTW), and stuff it back into the new eCode module, which is a shame because it somes with 14 guage wire. You can cut off the city light wires and leave it in the housing to keep it watertight.
Wiring diagram?
Jump to
- Delica Canada General
- ↳ Member Introductions
- ↳ General Discussion
- ↳ Events
- ↳ Events - Other BC
- ↳ Events - Alberta
- ↳ Events - Saskabush
- ↳ Events - Manitoba
- ↳ Events - Ontario
- ↳ Events - Atlantic Canada
- ↳ Events - North Of Sixty.
- Delica Canada Technical
- ↳ L300 Engine
- ↳ L300 Body
- ↳ L300 Overview
- ↳ A/C & Heating Systems
- ↳ Cooling & Oil Systems
- ↳ Intake & Exhaust
- ↳ Drive Train
- ↳ Front & Rear Axles
- ↳ Suspension & Brakes
- ↳ Body Electric
- ↳ Body General
- ↳ A/C & Heating
- ↳ Cooling & Oil
- ↳ Drive Train
- ↳ Body Electric
- ↳ Body General
- ↳ L300 Technical
- ↳ L400 Technical
- ↳ Delica Modifications
- ↳ WVO and Biodiesel
- ↳ Pajero
- ↳ Strada
- ↳ Mitsubishi Vanwagon
- ↳ Mitsubishi Kei
- ↳ Delica Wiki
- ↳ Radio Communications
- Sightings, Stories & Photos
- ↳ Was it You?
- ↳ Member Trips
- ↳ Member Rides
- ↳ Delica Photos
- ↳ On the Web
- Purchasing & Importing
- ↳ Tool Swaps, Share, Trade
- Feedback
- ↳ Archives
- ↳ Vehicle Sales
- ↳ Sales by Other Importers
- ↳ Sales by Private Members
