Dual piston brake upgrade long brake lines
Posted: Tue Feb 13, 2018 2:21 pm
by north54
I've just finished upgrading to dual piston brakes and new lines. I've got a question for whoever has done this job using the Russell 7" long steel brake lines: My upper line is very long compared to the original rubber one and touches the frame. I assume over time it might cause the line to wear down.
Any users having an issue of wear and tear on their lines because of this?
Thanks.
- IMG_0146.JPG (489.8 KiB) Viewed 7762 times
Posted: Tue Feb 13, 2018 4:15 pm
by Growlerbearnz
No experience with this specific brake line, but could you slip a bit of rubber pipe over it where it touches? Or bend the tabs to re-angle the line?
Posted: Tue Feb 13, 2018 5:35 pm
by north54
Growler look at my setup if I bend anything on it it breaks from rust!
I'll try the rubber boot thanks!
Posted: Wed Feb 14, 2018 2:34 pm
by Growlerbearnz
LOL fair enough! I'm a big fan of the split rubber hose, held on with a cable tie or two.
Posted: Thu Feb 15, 2018 10:15 pm
by takeuchi
When I have a moment I'll check mine as I did not cover mine with anything.
How do the brakes feel?
Sent from my ONEPLUS A5010 using Tapatalk
Posted: Thu Feb 15, 2018 10:28 pm
by north54
takeuchi wrote:When I have a moment I'll check mine as I did not cover mine with anything.
Spongy as usual but a noticeably quicker response to stopping. Pads haven't bedded either so hopefully it gets better. I'll have to bleed them again and maybe adjust the rear drums.
Never got to changing out the rear hose to the metal Russell one so I'll do that before bleeding them again.
Posted: Sat Apr 14, 2018 9:08 am
by takeuchi
north54 wrote:takeuchi wrote:When I have a moment I'll check mine as I did not cover mine with anything.
A bit late but no rubbing on my end. Gave up on trying to make the bracket work.[img]
https://uploads.tapatalk-cdn.com/201804 ... 61a4f9.jpg[/img]
Posted: Sat Apr 14, 2018 3:45 pm
by Growlerbearnz
Tidy! Here's how I made the bracket work:
- IMG_20121212_104531.jpg (107.43 KiB) Viewed 7611 times
Bending the steel brake line is a bit tricky though, you have to be careful to bend it on as large a radius as you can, otherwise it'll kink and then you have to replace it.
Re: Dual piston brake upgrade long brake lines
Posted: Thu Jul 14, 2022 7:15 pm
by andrewbowerman1992
So I'm doing this upgrade this weekend and I'm wondering a few things.
Hub bolts
The hub bolts off of my old rotors are way too long for the new rotors that are on a few people's parts list for this job. Did you guys just put a washer underneath the old hub bolts so they wouldn't bottom out? If not where did you source the bolts?
Brake lines
Growler it seems like you bent your hard brake line so it would fit on that higher mount on the caliper. Does that make it so you don't have to buy a new brake lines or did you buy a new longer lines anyway?
- Long bolts
- 16578513064639035761044417919919.jpg (63.76 KiB) Viewed 3296 times
Posted: Mon Jul 25, 2022 7:17 pm
by lrp374
I can't remember having your problem. I also looked @
http://delica.ca/forum/viewtopic.php?f=97&t=18792 which I'm sure you did as well and can't find any mention of an issue. Hopefully you have a solution by now.
Posted: Mon Jul 25, 2022 7:35 pm
by lrp374
If you haven't already you may want to visit --
http://dinoevo.de/brake-upgrade/
Posted: Tue Sep 27, 2022 10:45 pm
by GreyDC
Growlerbearnz wrote: ↑Sat Apr 14, 2018 3:45 pm
That's a neat job! We may do the brake upgrade on my friend's van after we finished the last mods on his truck. The headache rack and
tonneau covers will be next after installing the brake pads.
