Re: L300 dual tank system q
Posted: Fri May 21, 2010 2:34 pm
you aint ignant, I is...jfarsang wrote:Ditto.
I've been searching on the net and can't find any reference.
Call me ignorant but I thought that some guys already pulled the tanks and worked on them here on the forum.
ive pulled both my tanks, but im not sure i fully understand how they worked so i havent chimed in yet...
there is a hose that goes from the bottom of one tank, to the bottom of the other, and its through that hose that the siphon drains the tanks together.
each tank has its own pickup and return hose. the pickup has screens and a float mechanism that when it drops, it cuts off the fuel supply, so as to not draw air. (the screens should be cut out to let WVO flow more easily)
i do not know anything about the wiring. i just left the sending stuff alone, and eventually it just quit working.
jesse, sorry i didnt post sooner, the least you can expect from your fellow delica.ca members is a little good info considering how much youve contributed...
