Mitsibushi Delica Van (Diesel) 4D56 1990 wiring diagram
Posted: Tue Aug 24, 2010 11:59 pm
by antigraviddy
Can anyone help with a fuse box diagram for the abovementioned VAN?
Thanks in advance
is it this one
http://i78.photobucket.com/albums/j86/b ... seBox2.jpg
or this one
http://www.delica.ca/forum/l300-main-fu ... s-306.html
Re: Mitsibushi Delica Van (Diesel) 4D56 1990 wiring diagram
Posted: Wed Aug 25, 2010 8:27 am
Yes, there is a forum on this site called "Delica Canada Technical". In that forum is a sub-forum called "L300 Delica Downloads". Get to know this website and you will discover marvels... smiles.
Since this is a technical question I've moved it to "L300 Technical".
Posted: Wed Aug 25, 2010 12:26 pm
by antigraviddy
I posted the question because i found conflicting diagrams
Posted: Wed Aug 25, 2010 1:06 pm
by Super Exceeded
I feel your pain. Right now I am using two wiring harness from two different L300's and Mitsubishi was good enough to use different colour wires in each harness. This has made duplicating very difficult.
Posted: Wed Aug 25, 2010 4:57 pm
by after oil
when in doubt always trust mystery machine!
heres one you can DL and print for your box...
Uploaded with
ImageShack.us
Posted: Wed Aug 25, 2010 5:02 pm
by antigraviddy
Thanks for that.
so no specific fuse slot for glow plugs then?
Posted: Wed Aug 25, 2010 9:03 pm
On this page in the L300 Delica Downloads forum are five manuals or schematics. Regarding the glow plugs I would recommend "Engine Electrical Manual". This is the shop manual published by the Mitsubishi Motor Corporation. In the margin of the PDF file is a sub-heading "Glow System", try that.
Electrical Wiring Diagrams & Manual for the L-300
Posted: Thu Aug 26, 2010 6:55 am
by Golf Cart
Antigraviddy,
Might be an idea to post your geographical location on your profile. That way, one of the many members can offer up a drive by to help you out.
K Guys ....................you know your our there !!!
Posted: Sun Aug 29, 2010 1:32 pm
by antigraviddy
Golf Cart wrote:Antigraviddy,
Any one in Taranaki, New Zealand?
Thanks for all your help people. I think through process of elimination I have discovered that it is the Glow Plug Relay system. Now i just need the part numbers
Posted: Sun Aug 29, 2010 9:56 pm
There's a guy called Dave in Auckland, New Zealand with a sky blue over white '90 L300 Exceed. He's a structural engineer and here is a link to one of his threads which may help you out a wee bit:
This is why it is a good idea to post your general location in your profile... smiles.
P.S.: Regarding the part numbers ~ Check out Delica FAQs forum or L300 Delica Downloads forum; the latter will lead you to OEM numbers rather than Canadian numbers.
Posted: Mon Aug 30, 2010 10:33 pm
by antigraviddy
Hey all
Thanks for information, i am slowly getting there. Can anyone tell me where the Glowplug controller is located? Thanks again.
Posted: Mon Aug 30, 2010 11:52 pm
I typed "glowplug controller" into the search engine (in the upper right part of this page) and this is one of the links that I found: help..glowplugs won't work anymore!!
Have a butcher's... smiles.
