Hello,
I bought my Series 2 Chamoix roughly a year ago and have nicknamed it the White Lemon. I've been getting an intermittent check engine light that I can't seem to make go away. The error codes are 41 - Throttle Solenoid Valve. (in the inlet air path) and 43 - Timing Control Fuel Pump System. The van runs fairly well, but I do get some black smoke on acceleration (more then I think is normal), some diesel knock when starting in the morning and fuel consumption is high (about 400km/tank). I had the EGR cleaned out, but have since capped off the vacuum hose to the actuator thinking that may be the cause of the black smoke.
I thought the error code 41 would be related to the solenoid and the throttle body as the series 2 has a valve inside the throttle body that a solenoid engages. I've tested the solenoid and it works fine. Butch (CVI) capped off the vacuum hose to the throttle body just in case it was slamming shut when it wasn't suppose to. The other error code, 43, I have no idea what's up with that. Butch did the injection timing on it, but to no avail. It runs better since he got his hands on it, but I still get these error codes. Wondering if anyone else has experienced this and how they may have dealt with it.
1999 Series 2 Chamonix error codes
Re: 1999 Series 2 Chamonix error codes
Disconect the battery and see if the codes reset when you reconnect the battery.
TLWF
TLWF
Hey greenfox,
Will give that a go and see if it works.
We met around 8 or 9 months ago in the Princess Auto parking lot in Coquitlam. I didn't have my L400 with me at the time though. Anyhow, thanks for the advice.
Joe
Joe
- Big-Bird
- Vehicle: 96 PE8W Spacegear
Here's the instrucitons from the UK Delica site:
http://www.mdocuk.co.uk/forums/viewtopi ... rror+codes
To get the error codes do the following
(ANYONE GOT THE OBD PIN TRANSLATION PIC????)
- Turn off the engine and remove the key from the ignition
- Connect pin 1 to the metal chassis, with a length of wire
- Start the engine as usual
- The dash will light up as usual and the warning lights will all go off
- After going out like a normal start the A/T light will begin a sequence of flashing on and off (error codes)
- A long flashes indicates 10's. Short flashes indicates 1. (So for an error code of 11 you get one long and one short flash)
- It may give more than one error code, these are separated by a short pause, otherwise it will just keep cycling through and repeat the codes again.
However there is a way to read the fault codes by using the vehicle dashboard A/T warning light and a bit of wire with a crocodile clip on one end. The gearbox computer stores errors so you don't have to do this at the time of the problem. Its memory is reset by disconnecting the battery, which will also have the additional affect of returning the gear changing back to its default setting until it adjusts to your method of driving.
DTC Probable Cause
11 ........................ Defective TP Sensor Or TP Sensor Circuit
15 ........................ Open Oil Temperature Sensor Circuit
16 ........................ Short Oil Temperature Sensor Circuit
21 ........................ Short Ignition Signal Circuit
22 ........................ Open Ignition Signal Circuit
23 ........................ Open Signal Line (ECT) From ECM To TCM
24 ........................ Short Signal Line (ECT) From ECM To TCM
29 ........................ Short Neutral Safety Switch Circuit
30 ........................ Open Neutral Safety Switch Circuit
31 ........................ Open No. 2 Speed Sensor Circuit
32 ........................ Open No. 1 Speed Sensor Circuit
41 ........................ Open Solenoid No. 1 Circuit
42 ........................ Short Solenoid No. 1 Circuit
43 ........................ Open Solenoid No. 2 Circuit
44 ........................ Short Solenoid No. 2 Circuit
47 ........................ Open Lock-Up Solenoid Circuit
48 ........................ Short Lock-up Solenoid Circuit
49 ........................ (2) Torque Converter Clutch Engagement Malfunction
50 ........................ (2) Torque Converter Clutch Disengagement Malfunction
51 ........................ 1st Gear Ratio Signal Incorrect
52 ........................ 2nd Gear Ratio Signal Incorrect
53 ........................ 3rd Gear Ratio Signal Incorrect
54 ........................ 4th Gear Ratio Signal Incorrect
OR YOU CAN USE THESE CODES WHICH MAKE MORE SENSE for the 4M40 and 4M41(Pajero)
L400 from July 1997 4M40T with electrically controlled fuel pump. Engine Data Trouble Codes.
11. Accelerator Position Sensor.
12. Boost pressure sensor.
13. Atmospheric pressure sensor (Inbuilt within ECU).
14. Fuel temperature sensor.
15. Coolant temperature sensor.
16. Boost air temperature sensor (Inlet manifold air temperature sensor).
17. Vehicle speed sensor.
18. Engine rotation sensor (Pump rotation sensor).
21. Engine rotation sensor (Crank angle sensor).
23. Idle switch No 1 (Mounted on the body at the firewall).
24. Idle switch No 2 (Inbuilt within the Accelerator Position Sensor).
25. Timer piston position sensor. (Within the fuel pump)
26. Control sleeve position sensor. (Within the fuel pump)
41/42. Throttle solenoid valve. (In the Inlet air path).
43/44. Timing Control Fuel Pump system.
46. Injection quantity correction resistance. Correction signal open or short circuit.
48. GE Actuator control sleeve position sensor (middle breakdown system).
49. Over Boost. Boost pressure over 155 kPa / 1158 mmHg
--. Engine ECU. Engine ECU defective.
DTC Probable Cause
![Image](https://scontent-b-sea.xx.fbcdn.net/hphotos-frc3/t1.0-9/10004041_837908472890286_3790281751539329895_n.jpg)
- Big-Bird
Here's another set of Mitsu Codes for 1997 vehicles.
Diagnostic Codes
Mitsubishi
Without OBD-II
11 Oxygen sensor fault.
12 Airflow sensor fault.
13 Intake air temp sensor fault.
14 Throttle position sensor (TPS) fault.
15 Idle speed control (ISC) motor position sensor fault.
21 Coolant temp sensor fault.
22 Crankshaft position (CKP) sesnor fault.
23 Camshaft position (CMP) sensor fault.
24 Vehicle speed sensor (VSS) fault.
25 Barometric (BARO) pressure sensor fault.
31 Knock sensor fault.
32 MAP sensor faulty.
36 Ignition timing adjustment signal fault.
39 Oxygen (O2) sensor fault.
41 Injector(s) fault
42 Fuel pump fault.
43 EGR fault.
44 Ignition coil (cylinders #1 & #4) fault.
52 Ignition coil (cylinders #2 & #5) fault.
53 Ignition coil (cylinders #3 & #6) fault.
55 Idle air control (IAC) valve position sensor fault.
59 Rear Oxygen (O2) sesnor fault.
61 Transaxle control module torque reduction signal fault.
62 Variable Induction control (VIC) valve position sensor fault.
71 Traction control (TC) vacuum valve solenoid fault.
72 Traction Control (TC) vent valve solenoid fault.
Diagnostic Codes
Mitsubishi
Without OBD-II
42 Fuel pump fault.
43 EGR fault.
- Vehicle: Delica L400 2nd gen
Did you resolve this and what was the solution?
Error codes were the solenoid pack that controls the egr and the throttle body. They commonly go south on the series 2. Amayama has them for about $200.
Black smoke in the end was the injection pump. Put in a known good used one and the fuel consumption and smoke has corrected itself. I also did the injectors, turbo, blanked egr, glow plugs, etc.
Are you getting an error code and what Are your symptoms?
Thank you. I will pass this on to the mechanic. On description of error to Rising Sun they said they thought it is Emission Solenoids. I'm in Nelson so have a local mechanic working on it. They did a bunch of work last year which really helped but the problem has returned. Loss of power uphill - black smoke, goes super slow about 40-60km.
