Electrical
Electrical
As I continue to search for headlight solutions it dawns on me that the battery is 24v. Does that mean the lights must be 24v? What about the daytime running lights add on, or the high mounted brake light? Ditto the turbo timer.
David
David
1991 Delica Exceed
- BCDelica
Have you picked up your Delica from Prime-Link? (Did you see my low roofed grey one I pickup on Friday?
I have searched the other forums and not heard of a 24 v Delica's. Does yours have 2 battery's? There is room for a second, it's a tight fit, but I plan to install a second on my wife's Delica. Napa sells DC converters if necessary, Princess Auto is likely cheaper. Guys who run military vehicles get them to run 12v accessories.
Hope your is 12 volt.
Ciao
Kev
Ciao
Kev
- Breadman
- mark
- Member's Photo Album: http://www.delica.ca/Photos
- Vehicle: 1994 L400
- Breadman
my mistake
Sorry it is 12v don't know where I picked up 24v from.
Should probably delete this whole thread so as not to confuse others.
David
David
1991 Delica Exceed
Fog lights
12v, you had me nervous there for a momemt with the 24v
My 90 Super exceed did not come with fog lights and I do need them for my morning commute.
Any where special to wire them up?
Thanks,
Dawg
Thanks,
Dawg
'90 Super Exceed
- BCDelica
Hey Dawg,
By removing the front nudge bars, or front bezel (On the mid 1990's and new) gives you a few wiring options to under the dash. From there you could mount them on the front bars, I would like a lower set then the ones on my Deli's, seems lower is better. Had 4 mounted below the bumper of my old Caddy and they work sweet in rain and fog; and I needed all the help I could get the way I drove that thing around. A nice switch can be installed beside (left) the rear defrost switch (that's where the regular fog light switch exists) or just to the right of the cigarette lighter, that's where my tank switch's are. There is translations of fuse local's on the aussie Delica forum.
I am still having a hard time trying to figure where to put my second fuel gauge on my Deli'.
And Paul, did your first Delica have a block heater in the cold weather version? One of the two I just ordered is a cold weather version. (No, I bought em' but they are for other people - we need more Delica's in Powell River.)
Good Luck
Kev
Good Luck
Kev
- Breadman
- BCDelica
- Vehicle: L300 poptop gasser
