Seals for front hub bearings
Exceedbrown
Vehicle: L400 exceed
Post by Exceedbrown »
Anyone have any luck sourcing a north American replacement for these hub seals?
Exceedbrown
Re: Seals for front hub bearings
The seal is for the inner bearing, and now it looks as though I need to source the bearing as well with some pitting on the race.
http://www.mdocuk.co.uk/forums/viewtopic.php?t=29769
Gives the Mitsubishi Part numbers for seals and bearings, but anyone have luck matching to a North American part?
Timmken USA can send but shipping rate is astronomical.
Big-Bird
Vehicle: 96 PE8W Spacegear
Post by Big-Bird »
Have you tried any or all of the JDM parts guys in the Greater Vancouver and or Victoria areas
Amazing Autos
CC Autos
Rising Sun Imports
Rocky Mountain Imports
Maximum Overdrive
Japanoid
I don't want to point to any one of these in particular but one or many of them will have what you need and it's probably a stock item anyway.
The other option is find a local Timken Dealer in your industrial Park and see if they would bring it for you in their stock order.
You could also ask the US supplier for shipping the parts to you via
US Postal Service which is way cheaper that a courier.......No brokerage costs either!
Exceedbrown
Thanks all we cross referenced bearing and seal with micro and were able to bring it in through napa. Pics attached in case anyone finds themselves in this situation
Kg bearing #32010
Dmr seal s25031837a
Return to “L400 Technical”
