Penticton
twnavin
Vehicle: 92 delica exceed
Penticton
Post by twnavin »
Hey, I'm new to the Delica crew. So, hi every one.
Does anyone use a mechanic in this area? Not that I need one but one around Penticton for the contact list. I've used Dean@japanoid and he was great. But that's
400km from here.
jskrepnek
Vehicle: 92 Delica Exceed
Re: Penticton
Post by jskrepnek »
Hi,
This question keeps getting asked, but there doesn't seem to be an answer - yet. There's been a Delica near Keremeos for a couple years now - the owners have used a local (to Keremeos) garage for work. But with all the Delicas popping up in the area, it's only a matter of time before there will be a go-to garage in Penticton. Let us all know if you find one ...
-- Joel
Re: Penticton
Welcome to the club. Penticton? Wow, these things keep popping up further and further inland. That is so cool!
Enjoy your new ride.
MardyDelica
Re: Penticton
Post by MardyDelica »
usually, when you do all the service for delica specially timing belt , water pump, adjust valve , tensioner , seals & other thing you will be good for another 80-90 kms before you change the timing belt again.
its not acctually hard if you do this but if not very hard , few mechanic dont like to work on this,
but if you need help spend time bring the van to richmond area, & will look after your van, no problem, i have mechanic & parts to fix your delica, no problem,
enjoy;
Cheers:
