Rear Blower quit working...
mac_stang
Vehicle: 94' L400
Post by mac_stang »
As the title says, the rear blower stopped working. fuses look good, rear/front switches light when depressed. Used the translation for the interior fuse block but i cant figure out how to remove them to check them.
Any ideas or suggestions would be appreciated as i have no idea even how to get to the rear blower motor.
Thank you all in advance.
Brad.
Big-Bird
Vehicle: 96 PE8W Spacegear
Re: Rear Blower quit working...
Post by Big-Bird »
Needle nose pliers and a gentle pull on the fuse will yield a result.
Your fuse block should have a removal tool as well that acts like tweezers.
Getting at the rear blower....that should be a last resort. Check the relays, fuses and such items first. The rear blower is removed from under the Delica.....and its not a fun job.
mac_stang
Vehicle: 94' L400
Post by mac_stang »
Sorry, i can remove fuses no prob...the translation shows what look to. e relays(next to fuse block) marked rear heater. Its those i cannot figure out how to remove.
Im at a loss, i get a quick flicker from the rear ac button while cranking the fan speed controller through its paces, but that is it. I broke the tabs off the relays next to the fuse block but they wont budge(with more than reasonable force)
Brad.
Big-Bird
Post by Big-Bird »
Ah, I see. There are 2 sets of relays. One is on the fuse block itself and controls power to the entire system.
Then there is another relay mounted to the lower portion of the steering column....is it this one you speak of?
BB
mac_stang
Vehicle: 94' L400
Post by mac_stang »
Staring up at the fuse block, the two(what look to be relays) are on the right of the fuse block.
Brad.
mac_stang
Vehicle: 94' L400
Post by mac_stang »
Well, removed and then swapped the relays on the right of the fuse block, and nothing...removed and swapped the two relays that are mounted above the drivers left shin and she came to life.
I will look for replacements but it looks like there connection just needed to be roughed up.
Brad.
Return to “L400 Technical”
