Rear view mirror, passenger dash handle removal?
del_man
Vehicle: L400
Post by del_man »
Both are bit wiggly and that's annoying, how to remove/tighten them?
fredt
Vehicle: l400
Re: Rear view mirror, passenger dash handle removal?
Post by fredt »
If it the mirror that loose on the mount to the roof? There are three screws under the plastic trim, you need to pop that off and tighten them up, if it's the mirror loose on the stalk? Then there is not a lot you can do :( time to scour the breakers for a replacement
del_man
Vehicle: L400
Post by del_man »
Its loose at the roof connection, i wondered if it unscrews or just snaps off.
Thanks.
What about that passengers handle?
fredt
Vehicle: l400
Post by fredt »
you need to pop the plastic trim plate off and under there are some screws that need tightening
thelazygreenfox
Post by thelazygreenfox »
The passenger dash handle is bolted on from the inside of the dash. Remove the glove box and you should be able to find the nuts on the inside of the dash.
TLGF
del_man
Vehicle: L400
Post by del_man »
fredt wrote:Image
So I tried to pop the plastic off, pulled down on the mirror, the whole thing snapped out of the triangular bracket screwed (3 screws) to the ceiling. Now I have the bracket that sits firm in the ceiling and the mirror in my hand. I seems that triangular bracket had worn off on the inside, tried to put the mirror arm back in, seems difficult, and besides, today is too cold to do that. Maybe a bit of epoxy glue will do the trick...
fredt
Vehicle: l400
Post by fredt »
damn! IIRC? someone on here or the UK site replaced their dodgy mirror with one from another vehicle
Return to “L400 Technical”
