I hope you are all well and had an enjoyable summer. After spending my entire summer on the road touring Provincial Parks, my van is in need of some love. It started with a fuel leak from the rear tank. My mechanic pulled it and it's now sent off to be resealed. As I was talking to my mechanic he noticed a few other things that I may need to attend to.
He said the top of the tank is pretty rusty as are the lines that come off of it. I thought about getting a new tank, but could only find one on ebay in the UK and they don't ship to Canada:( Not sure if I can can source a new fuel sender unit. I have a new one in my parts stash, but it's for the front tank and I'm not sure if they're the same?
He also said there was some leaking around the area where the turbo is. Is it cheaper to just replace the whole thing? I went online to look at replacing it and the prices were all over the map. Everything from $277.00 - $950.00.
He mentioned leaking around the injector pump as well. I had this rebuilt just after I bought the van around 7 years ago. I've put about 75 thousand K on the motor since. Could it be due for another rebuild already? Seems a bit premature to me....
The last thing he mentioned was that it could use new rear bushings. Are these easy to sort?
I should also mention my van is a 1993 Super Exceed 2.5 diesel automatic now with 157K on the clock.
I probably put close to 10K on the odometer over this past summer touring and sleeping in my van. It was epic. I don't mind spending a bit of $$ to keep it running well, just trying to be smart about it, which is sometimes very hard for me, lol.
Thanks in advance for any input and/or suggestions.
Phil
Call me BCDelica-less
