has anyone replaced the engine with a gas one?
Dewy
Vehicle: 92 Super Exceed
Post by Dewy »
the reason i ask this question as this maybe my only alternative to shipping one down here to mexico from canada. :o :shock:
Delicanadabc
Vehicle: Super exceed 91
Re: has anyone replaced the engine with a gas one?
Post by Delicanadabc »
Keep in mind that there are stock Delicas with a gas engine...
TardisDeli
Post by TardisDeli »
Hi Dewy,
We saw a gas model american version (2 wheel drive), and compared it side by side with our diesel 4WD Delica. The gas engine is Much smaller physically, so the hump in the rear engine wall was NOT there, engine wall was flat. The fan housing was a couple inches over, because of the smaller engine. Not sure what else in the engine bay was in a slightly different location, it definitely looked wierd, but if something is different by an inch it might be a big issue to connect stuff. Remember with a gas engine, you'd have to add different fuel delivery system and spark plugs etc.
Glen at CC autos was servicing his neighbours gas delica (factory gas engine install). email ccautos at telus dot net. I would totally trust his expert opinion.
Sympathy, Christine.
Golf Cart
Vehicle: 1992 Exceed
Post by Golf Cart »
Dewy,
Now that sounds like throwing money away. Might be time to think about just trucking the Delica home. I know the trip meant alot, but hey, shit happens. Better to retreat to fight another day, than end up running outa bullets ( and money) so far away from the homeland.
Instead of shipping an engine down to you, why not spend that money to trailer the van home? Don't know what the cost comparison would be, but I'm thinking you've got a lot more to consider than just swapping the engine: the fuel system, the fit (of the engine into the engine bay), the transmission (usually geared much lower for a diesel engine than a gasoline one), the instrument cluster (tachometer, specifically), etc.
39Ronin
Vehicle: Mercedes Benz Gelandewagen 300GD
Post by 39Ronin »
Also your current transmission is geared for a diesel engine, the gas motor may not have enough torque. If you were able to install the gas motor you also may have to re-gear.
Dewy
Post by Dewy »
all valid points compadres. I am still need to get under the van and take off the oil pan and take a look at how bad it is and then take it from there.
?towing any suggestions? i have CAA but.....
thanks
TardisDeli
Dewy, I just reposted the "Big Kudos" story of how Kathy and Brian got their sick delica home from arizona, in case it helps. christine.
loki
Post by loki »
jfarsang wrote:Dewy
In the US, you may find those engines at some wreckers if you can get to them.
Dodge RAM D50 pickup trucks 1979-1989
They came with the 4D55 which you can use in the Delica's 4D56T place.
Dewy
Post by Dewy »
thanks loki... i may have actually seen a dodge ram within that time frame just today
Christine, thank you so much for sharing your humbling story. I am inspired to write about my adventure as well.
