I met a guy at CVI a few months ago that said there is someone in Burnaby who makes a hidden hitch specific to the Delica.
Does anyone know the name of the guy or shop?
Thanks!
Hidden Hitch in Burnanby??
- Vehicle: exceed 5 spd
Re: Hidden Hitch in Burnanby??
the only place that I know in burnaby is E and H hitch, you will find it with a search. that is where I got my hitch. If I recall , it was 575$ more or less for mine( and I garanty the van will fall apart before the hitch does). hope this help. Pierre
- nvanadm
The name E&H kind of sounds fimilair, but I thought it was supposed to be around $350.
- MardyDelica
its about around 375 to 425 + tax., they do good job. but make sure ask them to take out the negative wire on your battery before they do weld so your ecu computer wont have any problem. pls mention this nbefore you give tho them. i already told them about this issue but in case remind them again pls.
cheers;
cheers;
http://www.delica.ca/forum/eh-towing-hitch-1035.html
That what I got , and it is rock solid. Mine was a bit cheaper because I got a 4 pin electric plug instread!
Sorry, it did quote the way I wanted it to. This is from Schwa!
Just got my van back from E&H hitch shop, cost was quite high, but it's extra beefy with a 6 Pole connector and the only thing they had to remove was the bumper: sway bars and spare tire are still functional.
More photos can be found here: http://intdata.homeip.net/gallery/delica-mods?page=2
Parts:
Custom 2" Hitch Receiver, tube, steel, bolts... $150
Utility Ball, pin & clip... $45
Connector Plug $10
Stop Light controller $20
Wire $5
Bracket $5
Labour:
Fabricate & install hitch receiver $250
Install Wires, controller & connector $45
Total, including taxes: $598.90
Parts:
Connector Plug $10
Wire $5
Bracket $5
Labour:
- nvanadm
Thanks guys...
Mardy, thanks for the advice. Do you know anyone who will do a hitch? I'd rather do it through you. I need to drop my van off for you on Monday to have my windshild resealed, and a few keys cut, but i'll give you a call tomorrow.
Pedro, that link for the pics doesn't work and I'd like to see some...do you have any?
Thanks,
Adam
Thanks,
Adam
weird!! the pics wont come up??? just search schwa original post with the search engine under E&H hitch or towing hitch. it worked for me with pics and all. But like I said, pricier but rock solid!!!! worth for me!! Pierre
- nvanadm
Thanks again pedro. I searched and found that thread among others and found what I was looking for. I guess I only need a class II as it will only be used for a bike rack...no towing.
Thanks,
Adam
Thanks,
Adam
