The $45.00 snorkel
thedjjack
Vehicle: 1989 L300 HITOP!!
The $45.00 snorkel
Post by thedjjack »
The $45.00 Snorkel 1/2 done...
Just need to weld up a new input into the airbox, connect, and urethane the body/pipe hole.
(I may bend it to follow the body line a little more)
Vehicle: -
Re: The $45.00 snorkel
Post by fexlboi »
Interesting....again. Not the most beautiful set-up, but I guess it works.
One tip. There are usually drain slots on every good snorkel head to separate the water out. Otherwise you drive around and collect rain water non-stop. With this set-up I also would recommend to use a water resistant air-filter like the K&N.
RichD
Post by RichD »
All hail Ghetto Snorkel!
See also this and this similar project.
Richard Dagenais
I think it needs a set of blue stripes.
thedjjack
Post by thedjjack »
I was thinking when I add the 3 inch pipe into the stock airbox box making it so the water could fall to the bottom there.
The last time I did this setup I put a screw in the top so I could put the snorkel head around backwards for rainy driving.
Maybe make a foam/oiled filter??? Or K&N.
I will update when I get around to fixing the airbox (few busy weekends coming up).
thedjjack
Post by thedjjack »
I could swap out the 4 inch to 3 inch 90 degree to a 4 inch to 4 inch 90 degree elbow and space it out so the 3 inch intake pipe sticks up so water can run outside?
What do yous think?
Vehicle: -
Post by fexlboi »
That might work, but you loose probably quite a bit of valuable airflow. How about using 4" 90° elbow with a 4" to 3" reducer piece on the 3" pipe. Take the reducer and cut a few slots around with the table saw. Also it would be good to add some kind of mesh on the air entry.
sasquatch-hunter
Vehicle: 2 Delica
Post by sasquatch-hunter »
Put a up-side-down flower pot (ala the Land Rover style) on it.
Or just do what many others have done on DIY snorkel's. Put on a Safari head. $40-70 8-)
thedjjack
Post by thedjjack »
jfarsang wrote:Or just do what many others have done on DIY snorkel's. Put on a Safari head. $40-70 8-)
It's the $40-70 problem...Think I have an idea, just need some time!
thedjjack
Post by thedjjack »
Changes:
-4 inch to 4 inch 90 elbow gives a little room around 3/4 of the 3 inch intake pipe sticking through the snorkel.
-added a water catch at the bottom to collect water before it enters airbox.
-small bend in pipe to follow body
-Really bad blue paint
Need to mod the airbox when out at the shop my welder is at.
mac_stang
Vehicle: 94' L400
Post by mac_stang »
for air flow...dead ends=turbulance, better off with the elbow.
the cops are gonna think u have a potato canon on ur deli!!
thedjjack
Post by thedjjack »
I was going to wait till it rains...does it ever rain in Vancouver?
And see how much water it collects. I think the new snorkel head will let most the water go out.
I will also get the wife to drive and see how much air I get with the 90 vs the potato gun setup where it will go into the box.
Jordan
Vehicle: 89 low roof L300
Post by Jordan »
I think the PVC cleanout is a great idea but never thought about air turbulence, maybe if you turned the TY around it would make it a smoother transition reducing turbulence.
thedjjack
Post by thedjjack »
Wanted to make it so the water would fall to the trap. I will get the wife to drive and try 3 different ways and see how much flow I get.
