Procedure for replacing low beam bulbs ....
Aciled
Vehicle: 94 L400 SE SWB
Post by Aciled »
I'm wanting to upgrade my low beam H4's. Wondering about the procedure in what order to remove items (driver's side dual battery area)
Thanks in advance,
EN :-D :M
Re: Procedure for replacing low beam bulbs ....
reach down and pull out the plug.
unscrew the rubber/plastic cap and there's a metal pin holding the bulb in. press down and pop out.
if you can't reach in there (small hands help), then you may need to pull the batteries to get in there.
to pull the batteries you'll need to pull the intercooler off. 10mm bolts.
Aciled
Post by Aciled »
jfarsang wrote:reach down and pull out the plug.
Thanks!
Return to “L400 Technical”
