Info on running wiring for Boost/Pyro on 94 L400...
Aciled
Vehicle: 94 L400 SE SWB
Post by Aciled »
Well I've managed to gather all my parts to install a RHD 2-gauge pillar pod. I'm wanting info on running the wires and tube (Boost) down the window pillar.
Image Image
Anyone of there know of some pics or have instructions ?
Thanks in advance,
EN :-D
psilosin
Vehicle: L400
Re: Info on running wiring for Boost/Pyro on 94 L400...
Post by psilosin »
Pics of the pillar pod! :-D
Did you source it local or have it shipped over from Australia or similar?
Aciled
Post by Aciled »
psilosin wrote:Pics of the pillar pod! :-D
Happened upon it on CL.... Looked under JDM parts. :-D
Mr. Flibble
Post by Mr. Flibble »
Do you have more pics of this setup? Glowshift sells RHD 2 and 3 pillar gauge pods, and I am wondering if there is room for the 3 gauge pod...
RickJ
Vehicle: 1994 L400 SE
Post by RickJ »
Hi I just ordered a similar pillar off ebay. In the meantime I have installed and wired my boost and pyro. As for power for the pyro, I found an unused plug behind the glovebox which has one terminal switched for 12V. Using a spade crimp connection I have robbed the source from there. The ground is attached to a chassis bolt in the same neighborhood. I teed into the light dimmer for the lighting power but it works in reverse to the dash lights so for now I just used the same power source as the pyro power. This means lighting at all times but for now this is something I can live with. A note, I bulb and green condom supplied sucks...I purchased 2 autometer brand LED replacement bulbs for 12 a piece at lordco and they are quite an improvement.
Rick
