Good day eh!!
Great info here. Thanks to Erebus for making things crystal clear.
The only thing I would like to add is the bolt specs.
M6-1.0 x 16
M6 = 6mm diameter
1.0 = thread pitch
16 = length in mm
You want 16 mm in length to compensate for the flat washer and lock washer.
Super simple mod but effective!
6 inch tailgate lift
- cosmo727
- Vehicle: 1996 Delica Starwagon Active World
mdevelden
- Vehicle: Vera, '99 Chamonix, PE8W
From the pics I am seeing L300s. Will this work on a L400?
thelazygreenfox
yes you need longer bolts otherwise they will strip out. The tailgate is a heavy piece and there's lots of strain on the shock.
Another option I found worked well is to cut a spacer piece (old plastic cutting board) and insert it on the top of the shock bracket. Yup, you guesses it, longer bolts!!!
Works on all delis L3&400.
MD
MD
