FalcoColumbarius wrote:yojimbo wrote:As an aside I prefer stiffer sidewalls on the L300, the roll center seems to load them a lot on the front on corners, and softer tires felt like the bus was rolling over the tire to the outside, stiffer tires didnt.
I didn't really notice that. I have usually run my tyres at 42PSI, both the Ps and the LTs (which have more plies on the side wall). Yojimbo, what PSI do you run your tyres at?
Thats a good question, I spent a long time on my softer sidewall tires playing with tyre pressures, they were the standard 215s so I tried them at the stock IIRC 28psi, that wasnt fun, I then tried different levels, I found 40 and above they felt overinflated, and settled on around 38. The newer stiffer tyres I put on I think are about 34, but I am a lot less fussy about that now the handling has improved!
Ironically though I have just taken a delivery of 0 offset Enkei alloys and tyres for the old girl, so it's all change again
