There is a shop here who he charge 75$$ pers wheel for machining a guy told me. 300$$ for 4. Aaaouchhh!!
Thank you
						Rim Compatibility
				P.Gaudreault
 - Vehicle: Mitsubishi Delica 1998 Chamonix
				P.Gaudreault
Re: Rim Compatibility
33 mm is the offset of our van and 6'' width. I found this info on the web. Do you have the same??
http://www.wheel-size.com/size/mitsubishi/delica/
If I buy rims with 0mm offset and 8'' width, it will looks good.
- Croftcastles
 - Vehicle: 1998 Super Exceed LWB V6 (PF6W)
Did you end up getting these offset rims?
Any idea if you kept the 33mm offset and went 8" wide, would your tires rub with the wheel cranked?
- Big-Bird
 - Vehicle: 96 PE8W Spacegear
Alberta Wheel Repair in Calgary charged me $40 per loose rim to CNC the center hole on my Toyota Steel rims. 15x8 with a .5" wider offset than stock so they give a wide stance.
Stuffed a set of 31x10.50x15 arctic claws on them...great winter combo.
				thelazygreenfox
Croftcastles
The answer is yes! One time I had a BFG AT KO and compared it to a Michelin of the same size 15x 9.50. The only difference was in the (1/2") width of the tire tread.
When cranked the BFGs hit and the Michelins didn't. Go figure but needless to say I bought the Michelins.
TLGF
TLGF
						- Croftcastles
Thanks Gents!
TLGF - I'm assuming you're running wider than stock rims? Also assuming the size of these Michelin's would be 30"?
