2000 V6 Delica 6g72 Head gasket job/kit
- Vehicle: 2000 delica v6
Is it possible to you to explain me or send a link on where I can see the year correlation of parts for my engine ?
I don’t want to bother you with more questions.
I guess what I want to know if the montero sport 95 was the last year that matched the delicate v6 up to 2002
thanks.
thanks.
- Terence Yuen
- Vehicle: Mitsubishi L300
I looked up the Mitsubishi electronic parts catalogue the cylinder head gasket kit for your 2000 Delica Space Gear 3.0L, and it was MD973160. I then looked up the Mitsubishi electronic parts catalogue the Mitsubishi Montero 3.0L in North America to see if it used the same cylinder head gasket kit, and there it was. MD973160 was applicable from 6/1994 to 4/1995 for models outside California.
Former: 1983 L300 L035PW 1.8 5M/T
Current: 2000 L300 P03W 2.0 4A/T
you are going to laugh....
https://i.imgur.com/sQAa3Sc.png
That is using the Vin, still I don't get to the same part number as you.
Now I know why, you were looking for the gasket KIT not just the individual headgasket , that is why I could not match the number...well now I know.
- Terence Yuen
By checking the kit, you can check that many parts match instead of just one part. And it is Montero and not Montero Sport.
totally agree, and yes montero not sport.
I found an interesting You tube video on when not to change the head gasket. It goes through, seemingly, all the tests you could do troubleshooting head gasket symptoms so you don't change it when not needed. Called "Schrodingers Box" https://www.youtube.com/watch?v=uVn-IDi7da8
He also lists a bunch of "don't do this" to eliminate changing the gasket again.
There are a few different linked videos and they were a good education for me. Gotta love learning without reading manuals.
MD
MD
Terrence and jamen
Did you buy the kit through Rockauto?
thx
MD
thx
MD
I will buy it from them, but I have not yet.
I'm pass all those test already, you have not seen how many bubbles I get in my reservoir....and the car run just fine BUT it will fail rather soon I think.thelazygreenfox wrote: ↑Sun Jan 06, 2019 2:26 pm I found an interesting You tube video on when not to change the head gasket. It goes through, seemingly, all the tests you could do troubleshooting head gasket symptoms so you don't change it when not needed. Called "Schrodingers Box" https://www.youtube.com/watch?v=uVn-IDi7da8
MD![]()
Re: 2000 V6 Delica 6g72 Head gasket job/kit
well I got the headgasket kit and a lot of gasket fit well but the headgasket does not match the water passages, some of the wholes are very small so now I'm wondering if is the correct one.
