Pathfinderscuba wrote:A few questions from a potential Delica owner:
1. Will a WVO kit work in a Winnipeg winter climate? I'm talking winter temperatures down to -40°C. Or will I be running regular diesel during the winter? What are the low temperature limits to using a WVO kit?
2. For your kit, is it just pour in filtered WVO and go?
3. How is performance affected on WVO?
DS
You could still run WVO in the winter I would think but you would likely need to do a bit more fancy stuff on the install like a hotfox in tank heater and Hose in hose stuff to get the oil warm in the tank and keep it warm on the way up to the filter and IP, also some line heaters wrapped around the metal lines up by the injectors and a strong electric fuel pump at the tank to help push the oil up to the IP, but I think it is doable. I haven't actually done my install yet, and I'm going with a single tank system (I wouldn't recommend single tank for your climate) so I'm not an expert.
