Bouncing Speedometer needle
Re: Bouncing Speedometer needle
So great! Not only can you follow the bouncing needle to sing along with but now we have musical accompaniment by playing the mirror as well. Who needs a radio when you have all that?
- jwfchase
- Vehicle: '92 Super Exceed
The thing is, the sound just started last week, so unless something has changed on the mirror... the next thing I will check though, someone advised me there is a piece of rubber on top of the headlights (hidden away I think) that caused his to make a similar sound.
- jwfchase
So, after a trip to CVI and a very thourough inspection of the drivetrain and all 4 wheels (which was good to have done anyhow), turns out the problem was what lrp374 suggested it might be:
Along the top of the DEPO headlight pod is a strip of foam rubber, almost like a gasket, glued in place. Enough of the glue had worn out that the gasket was flapping at 60kph+ and producing a loud constant noise. It WAS wind noise after all! Anyhow, problem fixed, and taking the van to CVI turned up a separate suspension problem anyhow.
