Page 2 of 3
Re: oh no... not again...
Posted: Thu Oct 22, 2009 5:06 pm
by Green1
he's good, but the tow bill to get the vehicle there is a real killer! (and with only a month and a bit left until my new delica arrives, not worth it!)
Posted: Thu Oct 22, 2009 6:43 pm
by Green1
well... now I've done it...
So I can confirm that the problem was the crankshaft pulley, it basically fell off in my hand once the belts were loosened...
unfortunately I've now made matters worse.
The fellow whose house I had broken down in front of was rushing me, and I let him rush me... as a result I didn't pay enough attention to what I was doing, the vehicle started well, I did a U-turn to head home, and lost my power steering again, at the worst possible time. I ended up crashing hard in to a curb which destroyed my right front rim, possibly the tire, definitely the alignment, and who knows what steering components.
The vehicle also now refuses to start, though I can't fathom why, the starter motor is obviously spinning, but it doesn't seem to be spinning the engine with it... don't know if it managed to become dislodged somehow?
Either way, I'm thinking this is getting beyond my expertise, and I can't imagine spending the kind of money on this thing now that I would need to to get it going properly again....
I'm really stuck for ideas on what to do next, I might be able to do without the Delica until my next one gets here, but then what do I do with this one now??? I really want to get some of my money out of it, and there has to be a better fate for it than pick-ur-part, but I really don't know what to do anymore...
Posted: Thu Oct 22, 2009 7:22 pm
by after oil
:cry:
Posted: Thu Oct 22, 2009 9:58 pm
by konadog
bummer man... sorry to hear it.
Posted: Fri Oct 23, 2009 12:29 am
by wetcoast
Be a man and fix it! You have come this far... why quit now?? Could turn out to be cheap... maybe just the tow cost + a couple hours labour at a diesel shop. Like you said, its basically worthless unless it's in running condition. :M
Posted: Fri Oct 23, 2009 1:50 am
by Adam
wetcoast wrote:Be a man and fix it!
Not very sensitive, eh? Sorry to hear about the break down. There are few things more stressful than a potentially serious mechanical problem with one's Delica. We just have too much emotionally invested in these vehicles to brush it off. Believe me, I've been there.
Posted: Fri Oct 23, 2009 7:23 am
by Green1
wetcoast wrote:Be a man and fix it! You have come this far... why quit now?? Could turn out to be cheap... maybe just the tow cost + a couple hours labour at a diesel shop. Like you said, its basically worthless unless it's in running condition. :M
There's more to it unfortunately, If the vehicle was otherwise running well I would agree, but the vehicle runs piss poorly at the best of times, and I'm pretty certain that THAT problem is not going away short of a new engine. As a result we're talking about a minimum of several hundred dollars to effectively extend the life a month and a half (when my L400 arrives), at which point it may not actually affect the resale value anyway due to the bigger underlying issue.
Anyway, I gave up and had AMA tow it home for me, I don't have time to do anything with it today or tomorrow, but I will investigate it further on Sunday. Wish me luck.
Posted: Fri Oct 23, 2009 5:44 pm
by Erebus
Green1 wrote:As a result we're talking about a minimum of several hundred dollars to effectively extend the life a month and a half (when my L400 arrives), at which point it may not actually affect the resale value anyway due to the bigger underlying issue.
I certainly know that feeling! I had already purchased my Delica, and it was being shipped over from Japan when the mothership sensed it was being replaced. In short order it needed a new exhaust system. Then the alternator went the afternoon before my significant other went into hospital for an operation -- took taxi to and from hospital. Kirkham did their usual above-and-beyond and replaced the alternator by that afternoon.
Couple of days later it turned out the alternator took out the battery.
So I feel for you. Don't have any technical advice though :-(
Posted: Sun Oct 25, 2009 8:28 am
by Green1
ok, well my crankshaft pulley bolt and washer are completely missing... :shock:
Is this something I can source locally? or do I need a "special magic mitsubishi bolt and washer" to replace these?
Posted: Sun Oct 25, 2009 8:54 am
by mararmeisto
It's probably metric, but other than that it shouldn't have excessive magical powers.
Posted: Sun Oct 25, 2009 11:14 am
by bikepoor
Only because it's Sunday, and your stuck, try Parts Source or Canadian Tire, they both keep a minimal amount of Metric bolts, and nuts. Best to take the pully with you to make sure the thread count is correct, and the bolt long enough, with a head small enough to not hit the side of the pully for tightening.
Good luck, and don't sweat knowing you may be in over your head, you'll either learn how to swim or call for help and get it.
Posted: Sun Oct 25, 2009 11:29 am
by Green1
problem is, the pulley isn't threaded, it's the crankshaft that is threaded (a part that is much harder to take with me)
Anyway, I did a closer examination, and it turns out that the key-way on the crankshaft pulley is destroyed, and the key on the crankshaft is broken too, so it's more than a bolt that I need.
With the overall condition of the engine at this point, I'm not going to repair it.
I'm going to sell the vehicle "as-is" and hopefully someone with more mechanical ability than I will bring her back to life again. I have already had one person express some interest, so we shall see.
Posted: Sun Oct 25, 2009 11:36 am
by bikepoor
Bummer. Sorry man.
Posted: Sun Oct 25, 2009 12:52 pm
by mararmeisto
Green1 wrote:Anyway, I did a closer examination, and it turns out that the key-way on the crankshaft pulley is destroyed, and the key on the crankshaft is broken too, so it's more than a bolt that I need.
Bummer. For want of a 1$ bolt and a washer you'd have to spend a couple hundred dollars to repair that. Hopefully your next ride is not nearly as problematic as this one has been.
Posted: Sun Oct 25, 2009 6:43 pm
by MardyDelica
Hi, Sorry, to here this from you.
your L400 left japan already, in transit now will be here 1st week of nov.
will try to do all the service for your L400 rightaway when it arrived.
all parts & other thing to comply for this vehicle is all in hand. so just wait for few will be here soon;
again hope your o.k.
Cheers;
