winter driving
wannabe
Re: winter driving
So from what you're all telling me my Celica with weight in is really all I need? Yes my driving technique is good , I've been commuting on secondary, unplowed highways with the wind blowing across the road breaking trail at 5:30/6 in the morning. The left side drive would be advantageous as far as I can see as in bad wind/snow I drive by what I can see of the white side line on the road. Are L300's winterized? I sure like the look of them better! Do they have the Volkswagon cool air issues?
Re: winter driving
Who said anything about a Celica?wannabe wrote:So from what you're all telling me my Celica with weight in is really all I need?
There is a bright yellow line on the other side, too, and an L300 is about half the width of a standard lane.wannabe wrote:The left side drive would be advantageous as far as I can see as in bad wind/snow I drive by what I can see of the white side line on the road.
There are "winter" versions that have dual batteries, and thicker carpeting. Fact is that these mods are easy to add to any model. Also notable winter features would be LSD and throttle lock.wannabe wrote:Are L300's winterized? I sure like the look of them better! Do they have the Volkswagon cool air issues?
All L300's have dual heaters (AFAIK) front and back.
I have yet to test my heaters at below -15C but I think that these heaters can keep up with Canadian winters.
I intend to add additional insulation to my own L300, to bring it up to modern specs for road noise but also for winter camping.
No idea what a VW cool air issue is. Wimpy heaters maybe?
Richard Dagenais
Re: winter driving
The Chamonix was "built for the all season skier!" (not sure about the summer skier (maybe water skier?)).
My 1989 Chamonix has the winter package with
-hand throttle
-dual batteries
-Limited slip rear end
-fancy winter stickers
(i live in Vancouver at the moment, but I know what winter is (Williams Lake, PG, Northern Ontario, etc...))
It is a Diesel so to start in winter:
-good glow plugs
-big battery (or a few good ones)
-good compression
-plug in when possible
-good oil choice
-need to convince the fuel it will explode on its own (no spark plugs) so you need a good compression.
Remember 4x4 only gets you going it the snow....it does nothing to help you stop!
Good tires, remember higher center of gravity (helps in deep snow) makes ending up on side easier.
If I was doing backcountry trips at -40 I would pack a generator to warm up the system (oil pan heater, frost plug heater, battery warmers) after a long trip. (in the old days people would light a small fire and push the engine over it).
-hand throttle
-dual batteries
-good glow plugs
-good compression
-good oil choice
Re: winter driving
Just to clarify: The "Winter package" dual batteries are set up in parallel, which means they are still operating at twelve volts but delivering twice as many amps. The Miss Lil' Bitchi, a Chamonix and by definition a Winter package, has two 550 amp Globelites and delivers 1100 cold-cranking, deep-cycle amps on start-up, which is really beneficial in a Winter setting. Went camping one Winter on the sou-west face of Powder Mountain, nor-west of Squamish, at 900 metres; woke up at 01:30h in a freezer ~ 15* below zero, wind chill at -25*; I knew this might happen so I had my heating cranked and she started first time like a spring afternoon.
The Chamonix also has a more robust alternator; more clear coats on the paint job; the carpet and upholstery is more resilient, to take snow clad Winter boots, &c. ~ unlike the Exceed class Delicas, which are more luxurious with their shag carpets and velour upholstery.
It is my understanding that all Delicas up until 1992 possessed the manual throttle and from 1993 on had the automatic throttle.
P.S.: The MLB's decals read: "Built for all season outdoor player", which is good 'cause I don't ski worth a damn ~ but I do play... smiles.
Re: winter driving
I am sure I've said this in another thread but your understanding is not quite accurate; my 1994 L300 winter packaged Super Exceed has a manual throttle.FalcoColumbarius wrote:It is my understanding that all Delicas up until 1992 possessed the manual throttle and from 1993 on had the automatic throttle.
Richard Dagenais
Re: winter driving
I will double check ~ but my information comes from a few dealers & mechanics, as well as personal observation.
Re: winter driving
remember the motor only cares about temperature. Windchill has not affect on engines (except it will cool quicker when turned off) but only down to the actual temperature.
Re: winter driving
bump for winter driving
