Ok, back from my road trip, and there's a few issues that are quite apparent
I did not get any cardboard over the rad due to time constraints
I'll rack up on newb points with this, but what are all the 4 radiators underneath the van? I'm still new to this vehicle. Looking underneath I see 2 small radiators in front of each tire, plus the main rad on the engine, plus something as well right on the front nose of the van, behind the bush bar.
So a return trip between Calgary and Edmonton, temperature between -20 and -30 with blowing snow. I'm guessing driving through that wind at 100km/h equals around -50 or lower... So some pretty extreme conditions for this van.
The van did not warm up past 1/3 on the guage for most of the trip, a couple times it went up to half for a short while. Inside temperature didn't read much past 16, and I was fully bundled up and still a bit chilly. The heater was blowing slightly warm, never hot.
So I think it is obvious my thermostat needs replacing!
The 'outside' temperature on the console wasn't showing any colder than -19 the entire time, which I thought was strange, because it was much colder than that but perhaps has something to do with the faulty thermostat??
And a new thing, hoping someone has seen this:
3 or 4 times during both trips, the battery, a/t temp, and coolant(?) (next to A/t temp) lights would pulse on and off all at the same time. A few times i could see the headlights dimming as well, in time with the red lights pulsing. So it's some sort of electrical issue. I was running the fan on high, fog lights on, rear defrost, and mini inverter to charge my phone, so perhaps I was just overloading the charging system? When it started affecting the headlights, I would turn off some things, and it seemed to go away, but I would like to get this figured out... Anyone else ever experience this?
I wonder if all these issues are just due to the extreme cold that i've been driving in? It has been consistently below -10 since Christmas, and the last week or so has been much colder. Edmonton was around -30. Maybe my Deli needs a thaw??
Thanks for all the help thus far
Nate
