I was told to degrease/acetone/Pre-cleano 1st to remove any waxes/silicone before sanding (otherwise that stuff that paint doesn't stick to gets ground into the old paint)...then degrease again immediately before painting. Primer between old & new paint is worthwhile too.Steinbruchsoldat wrote:Same procedure as always: Sand with 240 grit, degrease with acetone and paint.
I'm going to rivet it in. There will be another brace that supports the weight.nxski wrote:It looks like you're going to be screwing that right into the body!? Are you adding extra bracing in behind to support the weight?
How can they reflect back in the window? I know about hood glare on roof mounted lights, but never heard about that. Can you tell me what causes this reflection, so i can prevent it?thedjjack wrote:I have my Hellas mounted up there test them first as I get lots of reflection back in the front window and need to make a shield up for them now...
UL YL300 :) nice !!Steinbruchsoldat wrote:Got the lights wired up, they`re insane bright...![]()
I have absolutely no reflections back in the front window. It's just awesome compared to the roof mounted lights on my blazer...FalcoColumbarius wrote:So how are the halos off the Hellas? Have you thought of mounting a shroud over the top of the lamp rack to cut down reflective glare?
