Page 49 of 59
Posted: Sun Jul 24, 2016 2:29 pm
majormalfunction wrote:almac wrote:
that's the strangest looking cb radio ive ever seen. can you give us some more details and more on your center console?
VHF is the black one
The cb is the yellow one
I just didn't attach the handset for the pic
They are in the center console
I might replace the console with a desktop bc box and put all the electronics into it AND have the PC running!!!
I take it you're a HAM?
You must propagate more of your frequency. QSY Radio Communications forum under Delica Canada Technical.What issue is you VHF? Charlie Quebec.
73, Falco.
Posted: Sun Jul 24, 2016 4:15 pm
by majormalfunction
73, Falco.
Yes I am
what do you mean?
There is No issue with any of my radios
Posted: Sun Jul 24, 2016 8:50 pm
Yes I am
what do you mean?
I mean what make, I didn't recognize the radios.
Posted: Sun Jul 24, 2016 10:41 pm
by majormalfunction
Yes I am
what do you mean?
ah
VHF is Yaesu FT-1900R and 3 handhelds... 2 baofengs (VHF/UHF) and 1 wouxun (VHF/UHF)
I forgot what Radio Shack Model the CB is but I also have two handheld CBs
I am looking for new ones for cheap.... Good luck
Posted: Mon Jul 25, 2016 6:36 am
by Lapprentis
Had to fixed the Front Sunroof Window after having almost lost it on the highway and got me scary for a few seconds....
The 2 front scews probably got loosen one after the other and then the sunroof opened the wrong way.....Had to drive a few km with one hand on the steering and the other one holding the glass
Later put temporary screws waiting for new one to come in
Advice: check yours once in a while
Lapprentis
Posted: Mon Jul 25, 2016 11:06 am
by majormalfunction
Lapprentis wrote:Had to fixed the Fronl Sunroof Window after having almost lost it on the highway and got me scary for a few seconds....
The 2 front scews probably got loosen one after the other and then the sunroof opened the wroug way.....Had to drive a few km with one hand on the steering and the other one holding the glass
Put temporary screws later waiting for new one to come in
Lapprentis
thanks for the tip
Mine used to get stuck open
I got it fixed but now i never open it
Posted: Mon Jul 25, 2016 4:07 pm
by majormalfunction
finalizing some stuff but...
where the hell can I get a hitch for the front?
I was told e&h...
those guys don't know anything about delicas
Does someone have any info about someone they KNOW that does Delicas??
Posted: Tue Jul 26, 2016 9:01 am
majormalfunction wrote:finalizing some stuff but...
I was told e&h...
E&H in Burnaby.
They have done a great number of Delicas, both Starwagon and Space Gear, including mine. They know Delicas.
Address:
5890 Beresford St
Burnaby, BC
V5J1J1
Phone: 604-433-4611
Posted: Tue Jul 26, 2016 11:04 pm
by majormalfunction
FalcoColumbarius wrote:majormalfunction wrote:finalizing some stuff but...
I was told e&h...
E&H in Burnaby.
Address:
5890 Beresford St
Burnaby, BC
V5J1J1
Phone: 604-433-4611
Awesome Thanks!
Actually I already spoke to Chris in the morning from the Surrey Store
Nice guy
They are going to make me a custom one
Seems like a lucrative market
someone should jump on this!!
Sound Insulation
Posted: Wed Sep 07, 2016 10:16 pm
by Morganizer
I put sound insulation foam on the front wheel wells, and in the foot wells. I did the rear wheel wells and the floor in the back previously, and it made such a difference I finally got around to doing the front.
I did this two Saturdays ago, and waited to post this til I took it on the highway, because that's the real test. The real indicator of how much quieter it is, was when I turned on the radio, and the volume was much louder than it needed to be. How's that for a before-and-after?
The foam I'm using is about 3mm, closed cell foam. Comes in a roll. I applied it with water-based contact cement. That stuff takes 30-40minutes to tack up, but I just worked it in sections, cut the next piece while waiting for the glue to dry.
(I suppose if it rolls and catches fire, I'll have molten foam dripping on me. But I mostly try not to drive that way.)
I've got another post on here about doing the back...
I might also do the insides of the door panels. I have to get in there at some point to deal with jumpy locks.
Posted: Fri Sep 09, 2016 12:04 pm
by vanontherun
REPLACING MY GLOW PLUGS
The local Lordco sold me the Wrong Plugs NGK 2161 Y-116R1 for a 98 l400 4M40 turbo diesel manual transmission.
I didnt know any better so I installed them. OOPS
I now have a reliable and experienced local DELICA mechanic - Okanagan BC - that has connected me to the Right Parts. NGK 90066 CZ256.
Dont do this to your Deli
Posted: Tue Sep 13, 2016 8:32 pm
by willskigilbert
Today I had a quick lunch some time before going back to work so I fixed the electric side step. With plenty of lube and by resetting by going to the max and min position with the big screw that is conected to the electric engine . It now works like a charm. Back from work I fixed the driver door little sensor it was giving wrong indications. I had no cabin light when I was opening the door and no indication if I let the lights on. Not a big deal but annoying. Went to the post office my north shore bike rack was there . Assembled it and no it's on !
Not to bad of a day !
Posted: Fri Sep 23, 2016 1:55 pm
Well, I've changed my wiper blades. Funny how it happens, one moment they are working fine then the next they are stuttering across the windscreen. I haven't checked my log book for the price I last paid but I'm pretty sure last time I paid around $20 for a pair. This time I paid $18 for one. Thirty-six bucks later I have clear vision! Now I'm going to go back to the garage and change my oil, rotate my tyres and grease all ten nipples.
Posted: Tue Sep 27, 2016 8:52 pm
by msimps
Posted: Tue Oct 04, 2016 12:45 pm
by johnarlene
30 mpg usa gallon, 36mpg imperial gallon. 8.1 litres per 100 kilometers. I do not understand how I am getting this kind of mileage in my 1997 gas engined 3litre space gear. I have done four mileage checks, total kilometers divided by total litres used. This is based on driving throughout the B.C. interior. Lots of hills and curvy roads getting to remote lakes and such. They all come out about the same. Maybe it was re-tuned somehow in Japan before I imported it.
What does anyone think? Or what does anyone know?
I know it sounds odd but really this is true.
Happy trails
