name that tune
Posted: Fri Mar 18, 2011 1:38 pm
by bassnailer
So there a new sound coming from somewhere around the front end. I can't think of how exactly to describe the sound. It's sounds a bit like a bump, like something might be loose; a combo between that sound and the sound the transfer case makes when you back out to unlock the hubs.
I hear it when we hit a manhole cover/ bump in the road, sometimes when turning. Could be a CV joint? Anyone wanna go for a ride and hear it for themselves? (cheaper than putting it on a hoist, I'll buy coffee).
Re: name that tune
Posted: Fri Mar 18, 2011 1:52 pm
by nxski
Sway bar bushings, shocks, or tie rods? Good places to start looking...
Re: name that tune
Posted: Fri Mar 18, 2011 10:49 pm
by tonydca
My L400 ball joints were shot after a good off-road thrashing. Drove me nuts; every little imperfection in the road made an annoying "clunk". Those rubber bits start to degrade after so many years. I understand sway bar/control arm bushings and related parts are likely culprits too.
CV joints is typically a rhythmic knock-knock-knock when turning a corner under load, even on a smooth surface.
Re: name that tune
Posted: Fri Mar 18, 2011 11:21 pm
by bassnailer
tonydca wrote:...ball joints were shot after a good off-road thrashing. Drove me nuts; every little imperfection in the road made an annoying "clunk"...
That sounds like what I'm dealing with. I see a pothole and I cringe. I was going to get under tonight and have a look around. But I was first fiddling with stuff under the drivers seat when my neighbour came out, and one beer led to another....
Re: name that tune
Posted: Fri Mar 18, 2011 11:26 pm
by thedjjack
The sub frame on the 300L also needs re-torqued and can make a similar sound
