aftermarket stereo / amplifier
Posted: Fri Apr 01, 2011 1:45 pm
by westendah
I am wondering if there would be an issue installing a 180 watt stereo with a 400 watt amplifier in a L400 - would it draw too much power from the alternator and kill the battery?
Re: aftermarket stereo / amplifier
Posted: Fri Apr 01, 2011 1:49 pm
by nxski
I certainly hope not as I'm installing a 1400 watt amp with 2 400W subs in an L300. That's not a lot of power so you should be fine. I'm just going to hope for the best
Posted: Fri Apr 01, 2011 8:22 pm
by Mr. Pistachio
nxski wrote:I certainly hope not as I'm installing a 1400 watt amp with 2 400W subs in an L300. That's not a lot of power so you should be fine. I'm just going to hope for the best
WHAT? CAN'T HEAR YOU!
Posted: Sun Apr 03, 2011 12:01 am
by nxski
Mr. Pistachio wrote:nxski wrote:I certainly hope not as I'm installing a 1400 watt amp with 2 400W subs in an L300. That's not a lot of power so you should be fine. I'm just going to hope for the best
It's to drown out the noise from the exhaust system I installed
