SILENT SHAFT BEARING HOUSING REPAIR
Amit Ghosh
Vehicle: mitsubishi pajero
Post by Amit Ghosh »
Does anyone have any ideas on how to repair the "silent shaft bearing housing"?This is a 4d56.
By the way incase your timing belts are breaking without any apparent reason please check this silent shaft.The bearings could be worn and the shaft sticks as it rotates.Hence shearing the teeth on the belt.Another good indicator of this failure is oil pressure light coming on below 1000-2000 rpm.
Strada 92
Vehicle: Mitsubishi Delica L400 1995
Re: SILENT SHAFT BEARING HOUSING REPAIR
Post by Strada 92 »
I know that for a mitsubishi 4g61,4g63,4g64 and other (hyundai,nissan,etc...),there is many elimination kit to remove the silent shaft that are available.
I'm sure that it is possible to do the same thing with the 4d56.
Check this kit,just to give you an idea.
http://cgi.ebay.ca/BALANCE-SHAFT-ELIMIN ... 1c1af2c43d
Mitsubishi L400 Spacegear
Mitsubishi I-MiEV 2012
Return to “Pajero”
