Stanadyne filter FM100 questions
Posted: Fri May 20, 2011 2:28 pm
by after oil
hi
the filter has 4 ports. looks like two are IN and two are OUT. which is which? has anybody assembled the primer pump on your FM100?
Re: Stanadyne filter FM100 questions
Posted: Fri May 20, 2011 5:55 pm
by Jordan
I don't have the primer pump but for the housing I think there is an 'in' and 'out' on each side with little arrows on the top, plug 2 of them or you can put a vac gauge on the extra 'in' to monitor filter life.
Posted: Fri May 20, 2011 6:52 pm
by after oil
thanks
i found a good image of the primer pump to see i had it right. good idea on the gauge. im gonna thread a heater in to there.
Posted: Fri May 20, 2011 8:02 pm
by Jordan
Where do you have your filter mounted? The primer has intrigued me but I would have to refigure some things as I have no clearance above the filter.
Posted: Sat May 21, 2011 2:46 am
by after oil
its in the battery compartment. there is only one battery in there, one of the two side by side style
