Page 1 of 2
turtle WVO install pictorial
Posted: Sat Jul 02, 2011 10:18 am
by after oil
hi
turtle is done! the pictures mostly say it all. a few deets though: the return valve is plumbed to another valve i can turn by hand to select return to tank, or loop back to IP, through an out port in the filter. i took off the hand primer and capped the filter again b/c i think the primer was leaking air (i suspect the filter assy still is still leaking air)
the tank is 120l aluminum w/ a baffle, bolted into the rear sway bar bolt holes.
Re: turtle WVO install pictorial
Posted: Sat Jul 02, 2011 10:22 am
by after oil
Posted: Sat Jul 02, 2011 10:56 am
by delicat
Congrats!
It was only a matter of time with you, we all knew it was coming!
Nice custom install, I especially like how you mounted and attached your tank, great idea!
Enjoy the grease!
Mr. D
Posted: Sat Jul 02, 2011 11:19 am
by fexlboi
Well done after-oil!
Are the clear coolant hoses rated for high temperatures?
Posted: Sat Jul 02, 2011 11:33 am
by after oil
fexlboi wrote:Well done after-oil!
thanks...
maybe they aint rated for high temps.. but theyll hold... i think...
ive used them on other installs with no problems, but before my drive through the Nevada desert this summer ill put real heating hoses on there..
how much pressure is a cooling system anyhow?
Posted: Sat Jul 02, 2011 12:32 pm
by fexlboi
Just read a few times on other forums that people running into problems with the clear hoses as they are rate for around +65°C max. If the temperatures rises the rubber gets pretty soft and they might slip off the barbs even with hose clamps.
Posted: Sat Jul 02, 2011 12:59 pm
Service Specs. for the 4D5:
Items;__________________________________________________Standard Values;____________________Limits;
High pressure value opening pressure of radiator cap kPa:_______74 - 103___________________________64
Range of coolant antifreeze concentration of radiator % :________30 - 60
Thermostat: - Valve opening temperature of thermostat *C:_____________82 +/- 1.5
- Full opening temperature of thermostat *C:______________95
- Valve lift mm:_______________________________________8.5 or more
Posted: Wed Jul 06, 2011 7:35 am
by after oil
First highway trip yesterday from comox ferry to Vic and back: ALL GOOD
im pretty sure the filter assy is still leaking air. on the way down at times there was a bit of hesitation (maybe) but on the way back did the speed limit or more, climbed the Malahat no problem!!
Posted: Wed Jul 06, 2011 7:50 am
Looks great Ari !
Posted: Sat Jul 16, 2011 12:59 pm
by psychadelica
What's your speed over the Malahat in the L300? If I am on my own I have to drop to about 60kph and with a car load of people, man, I must drop to 40 or 50kph on the steeper parts.
Posted: Sat Jul 16, 2011 6:31 pm
by after oil
sort of depends where.. heading north, i can keep 70-80 going in the beginning, and down to around 70 coming up by the shawnigan lake turnoff
Posted: Mon Jul 18, 2011 3:16 am
by Jordan
Great install, every aspect of that vehicle is so beautiful.
What kind of switch is this?
Posted: Mon Jul 18, 2011 8:13 am
by after oil
Jordan wrote:Great install, every aspect of that vehicle is so beautiful.
its the brains of the system. its a 3 way toggle, 1 diesel, 0 veg - glow plug, 2 veg + glow plug
theres relays and a micro chip in there that delays the switching of the return valve to allow for a good purge.
Posted: Mon Jul 18, 2011 6:48 pm
by Jordan
after oil wrote:Jordan wrote:Great install, every aspect of that vehicle is so beautiful.
Who makes it? What is the purge time?
Posted: Mon Jul 18, 2011 6:49 pm
by Jordan
Does the glow plug cycle to keep the oil at a certain temp or does it stay on? What temp does your oil get to?
