Inclinometer Ball for L400
Posted: Fri Dec 02, 2011 1:17 pm
by prairiefire
I'm looking for a working or non-working Inclinometer ball for my L400. Mine has been painted over by the dumb@$$ I bought it from. Anyone know how to remove spray paint on plastic without damaging it? Acetone perhaps?
thanks,
K
Re: Inclinometer Ball for L400
Posted: Fri Dec 02, 2011 7:08 pm
by Pajero
acetone may damage the plastic, but if its already useless then not much to lose my trying. I took mine out as i replaced it with a EGT gauge, So you could have mine but the greenish liquid has leaked out some where i think its supposed to be 1/2 full its only a 1/4 full
Joe
Posted: Fri Dec 02, 2011 7:41 pm
by claude
Pajero wrote:acetone may damage the plastic, but if its already useless then not much to lose my trying. I took mine out as i replaced it with a EGT gauge, So you could have mine but the greenish liquid has leaked out some where i think its supposed to be 1/2 full its only a 1/4 full
Joe
Same problem , mine has no liquid in it. How hard it is to install a EGT gauge
Claude
Posted: Fri Dec 02, 2011 8:35 pm
by Pajero
It was not too hard to do took a little time, but I bought the EGR blocking plate from here that had been drilled and tapped to fit the temp probe. If you do a search on here you can find more info on it. Its a good thing to have especially if you are going to tow anything.
Joe
Posted: Sat Dec 10, 2011 4:49 pm
by claude
Pajero wrote:It was not too hard to do took a little time, but I bought the EGR blocking plate from here that had been drilled and tapped to fit the temp probe. If you do a search on here you can find more info on it. Its a good thing to have especially if you are going to tow anything.
Joe
I was wrong I took out the inclinometer and fund out it still had some liquid.
I shake few times and is working now
Posted: Sun Mar 04, 2012 8:56 pm
by prairiefire
Still looking. Pajero's have bigger balls than the L400.
Posted: Sun Mar 04, 2012 10:51 pm
by tonydca
PM sent
