Master Cylinder
Posted: Thu Dec 15, 2011 9:08 pm
by Raule Duke
does anyone know if the north American model's Master cylinder will cross over to the JDM's?
also seems as tough there are two center bores 7/8" or 15/16" any idea which ours is?
cheers
CJ
Re: Master Cylinder
Posted: Fri Dec 16, 2011 12:34 am
by lopar
Raule Duke wrote:Master cylinder
Brake or Clutch? :mrgreen:
Re: Master Cylinder
Posted: Fri Dec 16, 2011 1:00 am
by Rising Sun Auto Import
Raule Duke wrote:does anyone know if the north American model's Master cylinder will cross over to the JDM's?
cheers
CJ
It seems he is talking about brake master cylinder.
If that is the case,15/16" is correct and I don't think there are part crossover in NA cars.
You may get a used one or new one from Mitsubishi ( over $400 I guess ).
Of course some manufacturers in China supply them at cheap price.
Steven
Posted: Fri Dec 16, 2011 9:13 am
by Raule Duke
Yes I mean the brake. (isn't the slave cylinder the clutch?)
Re: Master Cylinder
Posted: Fri Dec 16, 2011 11:31 am
by lopar
Raule Duke wrote:(isn't the slave cylinder the clutch?)
Most hydraulic systems have some form, or variation, of a master cylinder and slave cylinder. The master cylinder controls the slave cylinder (as implied in their names) usually to achieve either power or increase in range of motion.
Re: Master Cylinder
by lopar
Re: Master Cylinder
Posted: Fri Dec 16, 2011 1:40 pm
by Artie Fufkin
this thread would make more sense if I knew what a master cylinder was .. :shock:
AF
Re: Master Cylinder
Posted: Sun Dec 18, 2011 12:38 pm
by Raule Duke
It's the 6inch or so long metal thing below the brake fluid reservoir that is mounted to the break booster.
It is where the mechanical movement from your foot is turned to hydraulic power
