When the dealer/shops first began.. a worthy read
Posted: Thu Jan 26, 2012 4:47 pm
If you look at the current lineup of dealers/service shops, you'll notice that most have been around since the forum's early stages.
What I find humbling, is that back then, the vendors businesses grew by providing good service and via word of mouth.
The best part, if you want to know how a (honest to themselves) vendor carries themselves on this public forum, go and look back when they first joined.
You can see a big difference between the guys in business that genuinely put this forum/members ahead of dollar signs and helped this community grow.
Some began helping with the new 'Delica' and some began by immediately selling.
It's really a good read if you have the time to look through these guys's first few years on this forum. Really speaks the truth about their intentions in our small community of owners/enthusiasts.
There is no doubt that those first few years, this community was 100% fun where everyone wasn't ashamed to shake hands, chat and be friendly towards eachother regardless of where they are from or what they do for a living. Really good times.
Put in order from join date and just posting currently operating businesses:
Member name: ccautos
Sign up date: Sep 15, 2006
Join status: Signed up as a service shop/parts supplier
Current status: Service Shop/Importer
http://www.delica.ca/forum/advanced-sea ... &start=480
First 3 posts:
ccautos wrote:I own a repair shop in Coombs , Vancouver island . We have carried out many repairs on Delicas and have found many parts easily interchangable from parts stores locally . We also found some nice upgraded Monroe shock absorbers to give Delicas a slightly stiffer ride . I would be very interested in getting hold of a copy of the workshop manual if anyone is willing to sell a copy .
ccautos wrote:I have a repair shop in Coombs and have now carried out several alignments on Delicas . Tha main problem with these vehicles coming in from Japan is that the suspension is set up to give a small pull to the right to counteract the road camber for driving on the left side of the road . These vehicle need to be reset to give a small pull to the left to counteract driving on the right side . It takes about two hours to re-align the front to drive straight and with some upgraded Monroe shocks they are a very pleasant vehicle to drive . In fact i might just buy one soon as I spend all day road testing them and then jump in my Dodge caravan which isn`t quite the same !!!!
ccautos wrote:I have already bought in several vehicles from Japan and I keep seeing these Chamonix model Delicas . I know it is the skiing edition but does anyone know exactly what is different from a regular Delica ? I think I need to get me one of these Delicas !!!
Member name: mdrive
Sign up date: Nov 07, 2006
Join status: Signed up as an importer/parts supplier
Current status: Importer/Dealer/Service Shop
http://www.delica.ca/forum/advanced-sea ... &start=525
First 3 posts:
mdrive wrote:Air Filter $25.
Fuel Filter $20.
Oil Filter $20.
3 Pack Combo: $55.00
mailto:sales@maxoverdrive.ca
604-726-3109
mdrive wrote:Delica Tail Lamps on sale $50.00 Left or Right. Both for $80.00
mdrive wrote:Delica Waterpump on Sale. Limited Qty. $180.00
Member name: silkroad
Sign up date: Nov 12, 2006
Join status: Signed up as an importer/dealer
http://www.delica.ca/forum/advanced-sea ... 5&start=15
First 3 posts:
silkroad wrote:Silk Road Autos (http://www.silkroadautos.com) has 8 units of delicas on the lot and the price is the same as of you order one yourself from Japan. Please check us out!
silkroad wrote:Silk Road Autos currently has about 10 Delicas in high/low roof, crystal lite and aero roof, manual and automatic. For more information, please check:
silkroad wrote:Made in November and December 1992 becomes 1993 models
Member name: MardyDelica
Sign up date: Jan 14, 2007
Join status: Signed up as an owner
http://www.delica.ca/forum/advanced-sea ... start=1950
First 3 posts:
MardyDelica wrote:Hi, i am new member here,known Mark for a while,finally Mark made it thru with this forum. very familar with Mitsubishi Delica & Pajero turbo & intercooler Turbo diesel. i works as a parts supervisor back home in the phils. we always deals with diesel over there. i see this forum need help when it comes to parts. i'm here to help, parts can buy in local Mitsubishi dealer
Here is some orig. Mitsubishi Parts number you need:
Timing belt - MD134377
Balance Shaft belt - MD363481
Glow Plug - MD092392
Tie-rod end (Inner& outer are the same) - MB527650
Lower radiator heater ( a Must for mitsubishi delica when its in a cold winter from 0 degrees seem like mitsubishi engine dont like cold whether) when install it you wont have any problem to start even its -10 to -40 it will fired up will help the glow plug. also try to put diesel antifreeze 70antifreeze & 30% water to maximize the coolant.try to plug it min. at least 3 hrs before you start the car. you can buy this parts in local lordco parts store: Rad hose heater 1 1/2 inch size # 3200003 list 54.90 cheap
i get back for other parts number any question about problem with delica 4D56 engine, member can ask question about problem of this delica willing to help keep in touch. :)
MardyDelica wrote:Hi, sorry guys before i forgot,glow plug for delica 4D56 engine uses # MD092392 6.2 volts not 11 volts. 11 volts only use in New pajero V44 & V24 model pajero. pls do try not to put 11 volts glow plug in delica it might give you problem toward the glow plug system & computer ECU. this delica has computer ECU on board. another things to know. keep in touch everybody
cheers: :)
MardyDelica wrote:Hi, cc auto, i been dealing with delica for long time if you see green color on the top edge of the glow plug , it should be 6.2 volt original replacement like NGk only 6 volt.you can buy this to local dealer mitsu give the parts # i post for delica 6.2 volts with green tip color on it. if you recieved the delica with 11 volts on it maybe they change it in japan from a previous owner but beware 11 volts as for i know only uses on pajero & newest model delica 1994 with 2.8 liter on it.4M40 engine not 4D56, but new pajero V44 & V24 i did see uses 11 volts. its just how this mitsubishi works for them. also always check the continuity of each glow plug if there is no continuity the glow plug is burn.willing to help you if you need more info. keep in touch hope this will help you
Member name: Japanoid Auto Store
Sign up date: Mar 15, 2007
http://www.delica.ca/forum/advanced-sea ... 3&sr=posts
First 3 posts:
Japanoid Auto Store wrote:Hello, Japanoid Auto Store is a small dealer here in New Westminster, B.C.
We have started carrying many Delica items & services which might come in handy !!
More stuff everyday so be sure to check us out.
http://www.buysell.com/search/inventory ... =BC4004785
Thanks.
Japanoid Auto Store wrote:In support of the Delica Community, Japanoid will continue to champion JDM vehicles and all the cars we sell. We provide parts and maintenance for all Japanese cars, including domestic Japanese cars.
We have imported Delicas since our inception and we love the utility, practicality, reliability and durability of this great truck.
With our showroom and autoshop in New Westminster, BC we have three lifts, seven bays and our staff includes professional Diesel mechanics. We also import and sell all types of Delica parts and accessories from engine parts and headlights to ski racks and workshop manuals.
Sending thanks to the Delica community and to those who really believe in free trade, national sovereignty, and consumer choice for Canadians.
Japanoid Auto Store wrote:Hi there.
We will be lisitng ladders for High Roof Delica next week.
Thanks.
Member name: CVI
Sign up date: Dec 03, 2007
Current status: Service shop
http://www.delica.ca/forum/advanced-sea ... &start=135
First 3 posts:
CVI wrote:Re: A/C idle up adjustments. Mardydelica's right on checking and adjusting idle when the A/C button is pressed in to activate the compressor and idle up actuator on the injection pump. There is a linkage that pulls the lever up to increase idle for A/C. Proper adjustment of this is that when you turn on your A/C, the idle should just be maintained at about 750 to 800rpms. You shouldn't even be able to feel the idle go up. It should just be the same with or with out actuating the A/C. That proper adjustment saves fuel too... :-)
Re: Cold start... usually, the injectors nozzle tips jell up too or sticks specially when stored for some time. Assuming the glo plugs all work well, starting at cold weather should fire up easily and just try and control the idle up with the throttle knob or the gas pedal. Gummy or sticking injectors can be cleaned ultrasonically.
Re: Water separator sensor on the dash... it would be wise specially in this cold weather to fill up at half a tank to prevent water condensation inside the tank. It's true... water is really bad for the injectors and injection pump.
hmmm ... lots of things I learned after I got my nice delica. ... from Mardy of course.
Cheers and Happy New Year to all!
CVI wrote:Engine type for the delica is a 4D56 using a VE rotary injection pump. These pumps were designed with a cold start system where it delivers a lot more fuel at starting rpm like 150rpm. It is normal for you to see some black smoke everytime you start your engine either when it's cold or hot. Once the engine fires, the "fog of death" should be clear.
CVI wrote:Hi! just a word of caution on that screw. That's the full load adjustment and is factory preset to deliver the right amount of fuel at certain load conditions. The reason it's sealed with the cap is ....well ...they don't want us to touch it. There are a lot of shims inside the pump that eventually wears out thru time, fuel quality and kms run. When these shims wear, then another part called the plunger and barrel starts to deliver more fuel than necessary. These can be preset only with a calibration machine. So be careful, you can adjust it turning clockwise for more fuel and anticlock for less but only in very small increments. Good luck.
Member name: fivestarauto
Sign up date: Sep 27, 2008
Join status: Signed up as a dealer
Current status: Dealer
http://www.delica.ca/forum/advanced-sea ... 3&start=15
First 3 posts:
fivestarauto wrote::-)TOP MODEL!:-)
- 1991 mitsubishi delica super exceed, crystal lite roof.
- safety inspected.
- comes with a one year warranty.
- new oil and filter- new timing belt- balance and drive belts- new antifreeze- water pump- thermostat- hose clamps- two new batteries- new valve cover gasket.
- 4 wheel drive with limited slip rear end.
- new BF Goodrich mud terrain LT325/60/r15 With lift kit
- extras: -turbo timer - remote starter with alarm -block heater - wood steering wheel - baja fog lights -cool box -alpine cd player -ladder -chrome wheels, bumpers, rear end cover ext.....
Sale Price is $13,900 and any more questions please feel free to contact us... were a family business, so no need to feel presure when asking questions!!! 250 248 8311
http://www.fivestarautosales.ca
fivestarauto wrote:1993 Delica Jasper addition 137,000 kms,ICBC inspected, come with a one year lubrico warranty good across north america! $5,347 spent in wholesale parts and labour (coombs country autos) things done such as: carryout all necessary service and reairs for DOT, oil filter, new oil, tiing belt, balance belt and drive belts, timing belt tensioner kit, front engine oil seal set, used rocker shaft assembly, valve cover gasket set, water pump, thermostat, radiator cap, recored radiator, upper and lower radiator hoses, hose clamps, engine mounts, DOT headlamp set, corner marker lamps, DRL module, headlamp bulbs, inner and outer tie rod ends, teering rack boot kits, front sway bar bush kit, front brake rotors, front brake pads, front shock absorbers, wet batteries, wiper blade set, used steering wheel, antifreeze. new 10 ply nexen tires as well with 120,000 km warranty!
any more information please feel free to contact us! 250 248 8311 or http://www.fivestarautosales.ca
fivestarauto wrote::-)1992 Delica high roof exceed.:-) DOT approved, ICBC inspected,one year lubrico warranty, 7 passenger turbo diesel. priced to sell $12,900 parts and labour done such as remove and replace belts as necessary, timing belt, balance belt and drive belts, timing belt tensioner set, water pump, thermostat, hose clamps, front engine oil seal set.
any more information please contact us at 250 248 8311 or website http://www.fivestarautosales.ca
Member name: Rising Sun Auto Import (member name changed)
Sign up date: Nov 08, 2008
Join status: Signed up as an importer/dealer/parts supplier
http://www.delica.ca/forum/advanced-sea ... start=1170
First 3 posts:
Hi, everyone
i'm a jdm importer/dealer from Coquitlam,BC.
i have managed importing jdm cars/trucks since2006.
i apologize for the late exposure to Delica club.
i think i can get more useful infos from you.
also as a jdm enthusiast, i'll earnestly support our club.
current stock ; 3 p35w
Regards,
Assiniboine Auto Service
1992/4 super exceed, p35w, silver, crystal roof, captain seats, cooler box, auction grade 4/B,
super clean, only 77800km, automatic, after market spare key, grill guard, after market suspension ( lifted up a little ), alloy wheel, navigation system, TV, CD changer, sunroof, good tires. full package price ; $11900
this nice delica will get our full service from our professional engineer who has a lot of experience for small diesel engine and worked in japan for many years.
new timing belt and balancer belt
new water pump
new oil seals
new tensioner bearing
check all brake system and fix/replace if needed.
replace all fluids and filters.
all chassis regreased
check water leaking from outside van
check all safety and compliance for a road and registration
Thanks , Tim in Duncan, BC.
Enjoy your Delica super exceed!
