Passenger seat base mount point measurements
Posted: Tue Feb 14, 2012 2:59 pm
I took a rough measurement based on the existing swivel base I have installed in our L400 but require confirmation.
I would appreciate the measurements of the stock seat setup as per below from one of you guys when you have some time and a tape measure. The more accurate, the better.
inches/mm either or.
L400 passenger seat base/floor mount
Base - mounts to floor:
Front width - 11" wide
Rear width - 13.75" wide
Front to Rear length - 14.5" long
Upper sliding track - mounts to base above:
Length (front to rear) - 13 "
Width (side to side) - 17 3/8" wide
All measurements are from centre hole to centre hole
