o-rings
- Vehicle: L400
o-rings
So what kind of store would a guy call when looking for a specific o-ring? Hydraulic shop? I need a specific size o-ring, hopefully made of viton, for my surf's injection pump that isn't available from Toyota anymore.
Re: o-rings
Lauren did the same thing on his Surf before the whipsaw trip last year.
Last minute his IP leaked like a siv so he pulled it apart and walked into a Lordco and matched it to the closest one.
said it was a tight fit but worked well
Re: o-rings
take to a shop that specializes in pump rebuilds and see if they can match it up???
- Vehicle: L400
Re: o-rings
Hmmm I always seem to have as much luck at Lordo as I do at CdnTire here in Penticton. My prediction when I ask 'Do you have a selection of o-rings?' will be met with 'ummmm...wait what? ho rings? Wrong store buddy...I'd try at the mall at the jewlery store'
Re: o-rings
he said he got it from one of those shelves that have a bunch of different o-rings on them
Re: o-rings
There are only so many types of IPs on the market, Psilosin and they tend to follow the same pattern as I understand. I would think that a seal kit for another IP of the same type would likely work, at least for the most part ~ and there's got to be after market kits. The Delica Injection Pumps are VE pumps, where the injection tubes leave the pump in a square formation (::) but there are also in-line IPs (....). Do you know what the OEM number is for your Surf's IP? Which motor is it ~ 2.4; 2.8; 3.0?
Re: o-rings
is not acceptable for a seal. It works and seals or does not and leaks.FalcoColumbarius wrote:would likely work, at least for the most part
Confirmed with Lauren and his surf. Lordco off the shelve o-ring. Matched to size and viton brand. Generic part.
If you can't find it, I'll bet Sabir has one to fit.
- tonydca
Re: o-rings
Not sure on the size you need, but Harbour Freight in Bellingham will sell you an entire box of o-rings of all sizes for between $7 for nitrile, to $20 for viton. Might get lucky...
- Vehicle: L400
Re: o-rings
cOOl cOol. Thanks for all the options. Sounds like finding this o-ring should be easy like a Staples EZ Button.
Re: o-rings
Or easy like a ...
Lordco was great when I was looking for an o-ring for my bypass filter adapter. I bought 3 sizes that all fit and picked the one that seemed best when fitted. You just need to tell the kid (and by kid I mean person around my age
) behind the counter that you are positive they sell them.
