Electrical Woes
Posted: Mon Mar 12, 2012 6:23 pm
by ctidd
1993 L300
Symptoms:
Neither dash-lights nor corner markers turn on with wand control, headlights, hi-beams, brake lights and turn signals are all fine.
Fog light switch remedies above issues.
Oil pressure light periodically illuminates with the key turned two clicks, but usually not. Went through a flickering stage couple months ago.
Light behind heater/ac control unit does not work. Did for a week once then it was gone again.
Low fuel light does not illuminate. Never seen it light up, but the needle works.
Checked all fuses, nervous to start digging behind dash.
Possible diagnosis:
Combo switch is fried
Something else is fried
Looking for:
Suggestions,
Expertise,
A covered place to start digging for answers
and someone to receive beverages, combustibles, or currency in return for their help.
Re: Electrical Woes
Posted: Mon Mar 12, 2012 8:23 pm
jfarsang wrote:I suggest to get in touch with Jay (Tardisdeli)
electrical gremlins are in his genetics 8-)
http://www.delica.ca/forum/looking-for- ... 12681.html
Re: Electrical Woes
Posted: Mon Mar 12, 2012 9:12 pm
Also, check the fusible links in the battery bay.
Re: Electrical Woes
Posted: Mon Mar 12, 2012 10:09 pm
by TardisDeli
Sounds like typical Deli headlight switch dying problem,the oil light problem could be flaky oil pressure switch,the heater /AC light might be bad connections at the light bulb socket and you may not be going low enough to get the low fuel warning light on but i wouldn't make it a point to get there. Cheers Jay Tardis deli
