Leaky Transmission
Posted: Thu Mar 15, 2012 10:26 am
by Dalaran_Delica
I apologize ahead of time if this is already located somewhere else in forums but my searches turned up empty handed, along with my wondering through the FAQ's.
I need to replace the rear output transmission seal, it is leaking slowly. I cannot find the seal part number, or anything. I found the filter gasket and a few other but i am not sure if they are the correct ones. Well I know the filler gasket is incorrect. I am pretty ignorant when it comes to in depth mechanical stuff so some help would be greatly appreciated.
Thank You!
DD
Re: Leaky Transmission
Posted: Thu Mar 15, 2012 11:42 am
Go to the board index; scroll down to Delica Canada Technical; look for "FAQ & Technical Reference Libraries"; Click on Delica FAQ Section; Click on "Useful Links for Vehicle Part Identification Purposes."; scroll down to "JDM Online Catalogue" and click on that; enter your VIN into the Mitsubishi field and press enter. This will give you every OEM part number for your wagon, when it left the factory (stock).
