gas engine MUT2 connector location?
thelazygreenfox
Post by thelazygreenfox »
Guys
Anyone know where the MUT 2 connector location is on a gas engine Delica?
Mine's a 95 2.4 litre with two O2 sensors on a 16 valve engine. Supposedly there is one but it must be well hidden..... :-(
thanks
TLGF
Re: gas engine MUT2 connector location?
thelazygreenfox wrote:Some Delicas and JDMs came with scan plugs but only after 1995ish. I haven't checked if I have one under my dash somewhere??? The MUT-3can be purchased everywhere but the code reader is specific to a vehicle and hard to find. I found this- http://www.troublecodes.net/mitsu/
Outlander came out in 2005.
You may be asking on the wrong website.
Anyone else?
TLGF
Wayne
I've used an OTC EVO that talks to MUT2 via MMC on two V6's. The plug is there. It is on the left side of the steering wheel under the dash. Beside the foot rest.
This is another scan tool thread here: http://www.delica.ca/forum/mitsubishi-s ... 12639.html
thelazygreenfox
Jesse Thanks, couldn't see it, no wonder, it's black, expected a white connector. Good directions. :-D :-D
TLGF
Depending on your scan tool, you may need a cable adaptor.
My evoscan came with a batch of cables, one (1.3U) is for the 16pin hybrid plug for the following applications:
Mitsubishi Eclipse/DSM (1995 and 1996 support Hybrid MUT Protocol)
Mitsubishi 3000GT (Hybrid MUT Protocol)
Mitsubishi Eclipse (Hybrid MUT Protocol)
Off topic/On topic: Tony's post is over 2 years old in the other thread. :-D
MODS/ADMIN: can you please merge these three threads together as they are all the same topic?
http://www.delica.ca/forum/gas-engine-m ... 12877.html
http://www.delica.ca/forum/l400-obdii-o ... -6544.html
