Advice? Want to clean Front Air Conditioning condenser
Posted: Sat May 12, 2012 5:30 pm
Surprise! Amongst all the other treasures I keep finding, my van doesn't have a functioning A/C system.
There are a few things I will investigate based on similar posts I have seen; they seem likely culprits:
1) fuses
2) refrigerant level
However, while poking around in the hood, I noticed the condenser was covered in muck. The fins of the AC radiator were barely visible. I thought this could only be a negative, so I thought cleaning them might help.
My question is:
Is there anyway to clean the A/C condenser without removing it from the vehicle? If not, what is the best way to clean it once removed?
Of course, if I am going about this all wrong, I would truly appreciate redirection!
Thanks in advance,
Jamie.
1) fuses
My question is:
Thanks in advance,
Jamie.
