L400 Rotors
prairiefire
Vehicle: 1995 L400 Delica SWB
L400 Rotors
Post by prairiefire »
Just curious as to what are the best A/M front rotors to use. I've gotten various quotes from the usual suspects. I'm wondering how aftermarket rotors are holding up for people out there. I don't want to drop a couple hundred $$$ on junk that'll wear out in a year.
thanks in advance.
k
RichD
Re: L400 Rotors
Post by RichD »
Happened to pick up two sets of rotors in past few days from local parts places (edit: as mentioned up-thread: Maximum Overdrive, Rising Sun, CC Autos have L400 brake parts in stock for sure.). On one set I noticed that the machining provided no venting path from the inside to the outside of the rotor. The machining was otherwise really nice. Someone commented that this obstruction could catch mud offroad but also reduces cooling (i.e. wearing faster). Pricing was similar between the two.
Point being that they are not all exactly the same.
Richard Dagenais
mac_stang
Vehicle: 94' L400
Re: L400 Rotors
Post by mac_stang »
RichD wrote:Happened to pick up two sets of rotors in past few days from local parts places. On one set I noticed that the machining provided no venting path from the inside to the outside of the rotor. The machining was otherwise really nice. Someone commented that this obstruction could catch mud offroad but also reduces cooling (i.e. wearing faster). Pricing was similar between the two.
Care to share some part numbers?
Brad
prairiefire
So where did you get your "preferred" rotor from. I'm putting together my parts tomorrow. My front calipers are dragging so I need to get on it ASAP.
Thanks in advance.
