My turn signal acting weird, it stay blinking on the left even when i switch to the right or in neutral position.
Any suggestion?
thanks in advance
Turn signal keep on the left
- claude
Leo Tolstoy
Leo Tolstoy
Re: Turn signal keep on the left
Probably one of your posts is broken. Find an equivalent part from a Montero or Mighty Max, take them both apart, and build a good one.
- Vehicle: L400
- Vehicle: Delica L400
Turn Signal Problems
My left turn signal stays on even when indicator is returned to the neutral position...thinking I might need to replace relay.
Does anyone know where the turn signal relay is in the L400?
- claude
Re: Turn Signal Problems
I have the same problem stay left even in neutral or right, Keep on seaching but luck so far :(frozenskinners wrote:My left turn signal stays on even when indicator is returned to the neutral position...thinking I might need to replace relay.
Leo Tolstoy
Leo Tolstoy
- Vehicle: L400
You two didn't look at the link I posted just above your posts? ^^
It contains the location of the flasher relay and repair of the switch. With photos!
