A few brake questions
Posted: Fri Aug 17, 2012 9:47 pm
				Hey folks,
I just went to replace the brake pads on my L400, thinking that they were in need of replacement, only to realize that they were actually fine. This surprised me a bit for a few reasons:
1. Firstly, the level of my brake fluid in the master cylinder filler had dropped from max to about the midway point between max and low. It has been that way for a while now and hasn't gone lower and there is no sign of a leak in the system anywhere.
2. Secondly, the rear brakes just recently started squeaking a bit when braking in reverse and I have never changed them.
3. In March I pulled a 12' Uhaul trailer all the way from Vancouver to Yellowknife and as soon as I hit the cold temps the front right wheel started squealing intermittently, usually when breaking, and I read this could be associated with the combo of cold temps and low pads. The sound went away as soon as the weather warmed up.
4. My braking doesn't feel super shit-hot. Not alarmingly bad by any means but just not as responsive as I think would be ideal, however, that's basically how they've always felt.
A bit of history: I replaced the front pads a little less than a year ago when one of the front callipers seized. I replaced the calliper as well. The reason I thought that the front pads may have worn that much already was I attributed it to a combination of the long drive up here and braking while towing the heavy trailer and I also thought that my front brakes were braking too much because I lifted the van a bit but haven't put a spacer in for the brake compensator valve. Basically, I put Ironman shocks in the back and the front torsion bars had been re-indexed when I bought it so I figure its about 1.5" higher all round.
My questions:
1. Any ideas what is causing the squeaking from the rear when braking in reverse and the drop in brake fluid level? Rotors are in great shape and like I said, so are the pads. The wheels spin freely.
2. Should I be adding a spacer of some kind to the compensator valve?
Appreciate your help,
Thanks.
Z
My questions:
Thanks.
Z
