Coolant Temp Sensor and Mystery Vac Hose?
Posted: Sat Sep 29, 2012 2:16 pm
by CREGAN
Hey guys- quick question for you. I am changing my glow plugs and doing some general mainenance and I am trying to locate the coolant temp sensor. Which one is it?:
I also have moved the intercooler out of the way to work on these bits and bobs and I have a mystery hose that doesn't seem to have an end. Can someone identify this hose?:
Thanks in advance.
Craig
Re: Coolant Temp Sensor and Mystery Vac Hose?
Posted: Sat Sep 29, 2012 2:42 pm
by tonydca
Could try disconnecting and.or shorting them when the beast is running and see which one lights up the dash indicator.
Posted: Sat Sep 29, 2012 3:03 pm
by CREGAN
OK, Thanks to the boys overseas I have solved the coolant temp sensor question:
Now just to identify that vac hose. Wonder what it is for and if it is supposed to be disconnected?
Posted: Mon Oct 01, 2012 1:15 pm
by Diver
Do you have an EGR?
Posted: Mon Oct 01, 2012 1:20 pm
by CREGAN
No, I blanked it off. I used the adapter for that vac hose and it is still there. When I was moving the intercoler out of the way I heard something drop onto the bash pans below. When I took them off to change the oil I found a little cap with a mitsubishi logo. It fit and I think with my powers of deductive reasoning and my super detective skills, I would say probelm solved. I have been wrong before. Several times in fact. :-)
Craig
