Valve adjust
- Vehicle: LWB L400
Valve adjust
What's going on with my valves? Not a clue what style they are ( shim under bucket, hydraulic etc) and when is/ adjustment needed for lash?
Evan
Evan
- Vehicle: LWB L400
Re: Valve adjust
got the info on type and such... when are people doing adjustments?
- MardyDelica
Re: Valve adjust
you dont need to adjust the valve for L400 as its hydraulic lifter.
hope this help
cheers;
mardy
hope this help
cheers;
mardy
- Vehicle: LWB L400
Valve adjust
Thanks Mardy... I was curious cus when it's cold... -5to -10 if I don't let it warm up for a minute it will stumble slightly... Which makes sense for a diesel of this technology. Do you agree? I'm new to IDI injection lol :)
Evan
Evan
- MardyDelica
Re: Valve adjust
hi, yes, evan,
also you need to adjust the cold start valve to higher rpm up to 900rpm to make it smoother.
then when its hot it will settle to the proper idle will turn smooth. that was i notice thru my experience dealing with this L400 4m40.
also do chnage the oil all the time good oil. pls dont used 0/40 it it might destroy your engine; 5w40 is ok for deisel.
cheers;
cheers;
- Vehicle: LWB L400
Valve adjust
Yah I have 5 40 in it and change every 4000 km... Where is the cold start adjustment? I thought it was controlled buy ambient tempature?
Evan
Evan
- CREGAN
- Vehicle: LWB L400
Valve adjust
Beautiful! Yah the van runs perfect and starts beautifully I was curious about the sleight hesitation thanks so much everyone
Evan
Evan
- Vehicle: LWB L400
Re: Valve adjust
Well got at the cold start valve this morning and gave it about a 1/4 turn and we will see how it pans out over the next couple of days
Ps you need small hands not meat paws like mine to get at it! i have been working on big stuff for to long!
- Vehicle: LWB L400
Valve adjust
So I have now turned it 1-1/4 turns and no effect on idle... Is this normal?
Evan
Evan
