Lower Ball Joints
Posted: Fri Mar 29, 2013 1:46 pm
Hi all,
I just took my 2.8D Pajero to the shop to get safety inspected. I'm not living in BC. It's a 1996 SWB model.
He told me I need to get:
DOT Headlights (easy enough from Canadian Tire, standard round headlights)
Lower Ball Joints need to be replaced.
So I bought the ball joints off him, front left and right.
I've got one of the wheels off and I'm trying to figure out how to get the lower ball joint off. There is a large nut on the very bottom with one of those metal clip/fastener things on it and I have got that nut off, but now I don't understand how to get it off from where it attaches to the rest of the hub. The lower ball joint piece itself is fastened to the lower arm with 4 more nuts/bolts which are easily remove able from the bottom of the arm, but I don't think that will free it from the rest of the hub because where that large nut was fastened is going through a piece on the hub which doesn't appear like it will just slide out easy peasy....
Has anyone done this work before if so can you give me some pointers? I can't really afford $250+ for them to do it at the shop.
Thanks!
Here are some pictures with what I'm talking about. http://imgur.com/a/022qW
I was thinking....can I just use another jack and jack up that lower control arm to pop the ball joint out of where it attaches to the hub???
Thanks!
